First Post with Pics
Old Apr 10, 2006 | 02:40 PM
Lexbox's Avatar
Lexbox
Welcome to the CL family Excellent choice on the color.
Old Apr 10, 2006 | 04:33 PM
Kharizma's Avatar
Kharizma
welcome to CL
i have that same intake/ecu set up and i have that blue filter, how is yours so bright blue? what do you use to clean it and oil it? i currently use the K&N recharge kit but it makes my filter pinkish lol
Old Apr 10, 2006 | 06:00 PM
TLW's Avatar
TLW
Originally Posted by mantis
Engine pic with SRT Intake/ECU installed...
Cleanest engine on CL ...Congrats ...Keep It Simple
Old Apr 10, 2006 | 06:08 PM
iasc300's Avatar
iasc300
uumm looks good- real good- nice - and have fun
Old Apr 10, 2006 | 06:39 PM
GWELEX's Avatar
GWELEX
Here's another Welcome to CL!! Nice choice with the V8.
Old Apr 10, 2006 | 06:50 PM
TexasGS's Avatar
TexasGS
Congrats on the purchase and on jumping right in on the Mod craze . Great color! But I am a bit biased .
Old Apr 10, 2006 | 08:37 PM
GS3Tek's Avatar
GS3Tek
Wow, thanks for your comments guys.
Maintrain, did you replace the ball joints yourself or do you have a local mechanic? I started reading through threads and a riped joint can cause alot of damage...scary. I'll probably jack up my car tonight to take a look/feel.
Congrats on the new car.
Once you're on CL, there's no going back to stock.
A little late since it's dark already...might as well check other suspension components-upper/lower control arms, tie rods also. Go check out the suspensions/brake section.
I had the ball joints replaced also. Another clunk issue that I had was a bad front strut that was leaking. It also made a clunk noise when going over dips and bumps.
Old Apr 10, 2006 | 08:41 PM
LEXUS_KID's Avatar
LEXUS_KID
WELCOME
Old Apr 10, 2006 | 08:53 PM
DJC's Avatar
DJC
Congrats on the new ride, looks nice.
On the clunking noise...does it happen when you are shifting into drive or reverse from park? If so, its a common occurence and easy remedy. Since you just had the brakes done, have them check and replace the clips inside the brake calipers that hold the pads in place. I was told these can become weak and no longer hold the pad from shifting inside the caliper and causing a clunking sound when engaging drive or reverse from park. Happy modding.
Cheers,
DJC
Old Apr 10, 2006 | 09:05 PM
speedie's Avatar
speedie
Welcome to the Club and Congrats on the new ride....I may see you at an intersection one day...I'm in Gwinnett also..
Old Apr 10, 2006 | 09:07 PM
markgs4's Avatar
markgs4
sweet looking ride you got there. And trust me, when the mod bug hits, it's the begining of the end!!!
Old Apr 10, 2006 | 09:54 PM
tonysofly's Avatar
tonysofly
nice gs....and welcome, glad you caught the bug!
Old Apr 11, 2006 | 06:01 AM
mantis's Avatar
mantis
Many thanks on the comments, I really feel welcomed now.
Kharizma, my filter is actually darker in person. The flash on my camera is overpowering so it just washed the blue color out. That is the cleanest that filter will ever be
GSTek, DJC, that clunking noise happens every once in a while when I turn. And then I hear it again if I turn the wheel at a complete stop. I'll be doing some heavy searching/reading and then taking the car in this weekend. The funny thing is that I'll start reading about suspension problems and then end up reading about forced induction mods!
Old Apr 11, 2006 | 08:10 PM
DJC's Avatar
DJC
Base on your description and the amount of miles on the car it does sound like ball joints. Also ask them to check all of the sway bar (front and rear) connecting points. These have been known to make a clunking noise if not properly tight.
DJC
Old Apr 11, 2006 | 08:12 PM
bluelex's Avatar
bluelex
Welcome and congrats...
liazon
Mar 29, 2016 02:24 PM
JohnGS4
14
Feb 13, 2006 07:21 AM
TK288
IS - 1st Gen (2001-2005)
Nov 20, 2001 01:56 PM
qwert26
Sep 23, 2001 03:37 PM
