Help with power steering pump
Guys,
I guess today I blew my power steering pump. I am pretty sure that is what this is that is leaking but I wanted to verify before I drop $340 on a new one
Check out the pics and tell me what you think. It was really hard to take the pictures so bear with me.
Jonny
Jonny
Originally Posted by TLW
Did you check the rubber lines?
Jonny
This is another risk of over tightening of the supercharger belt. You stand a chance of wearing out the bearing on the PS pump.
I could be wrong, but then why else would this happen?
Either way.
Sorry Jonny.
Either way.
Sorry Jonny.
Either way.
Sorry Jonny.
Either way.
Sorry Jonny.
Well when we were removing the supercharger and bracket we found that one of the PS hoses was badly kinked. I think this was responsible for seizing the pump, or at least had a lot to do with it. This sucks!! This car has been on the road for about 1 day in close to 6 months
Jonny
Originally Posted by DASHOCKER
Sorry to here about this Jonny. A damn hose caused this crap
Did you use silicone hoses, or the stock rubber ones? Silicone hoses are less prone to crimp up.
Did you use silicone hoses, or the stock rubber ones? Silicone hoses are less prone to crimp up.It was a thick high pressure hose that actually got crimped - which is surprising because the hose is so tough. I just had LexusFTW over here who is one of my mechanics these days
Anyway, he thinks it is just a gasket that is the problem. It is a weird 2 prong metal gasket that is $3.69!! I will be a happy guy if that is all it is causing the problems - althought the way things are going right now I doubt it
Thanks dawg,
jonny
Originally Posted by GS4DOUGIE
Johnny-
Be cautious as the leakage can cause your alternator to fail from the fluid leak. Happened to me and I had to get both replaced.
Good luck-
D
Good luck-
D
Yeah, I was worried about this. Any ideas how to stop this from ruining my alternator - cuz alternators are not the easiest thing in the world to replace!!
Hmm, what do you think? Thanks for everything man.
Jonny
Originally Posted by Dx3
Hey man,
Thanks dawg,
jonny
Thanks dawg,
jonny
Good stuff to know. After it's all repaired, let us know what the true problems were and the fix.
A kinked hose makes sense and really sucks at the same time.
Did the leak come from the bearing wearing out and as a result of no oil? Also maybe the hose is so thick that a small bend will cause a kink inside. Seems like a smaller more flexible hose would be more suitable?
Originally Posted by UptownGS
a DIY power steering pump instructional post.... yayyyyy!!! c'mon you know you wanna do it!
it'll be easy!
it'll be easy!
Let me know if you need pictures
Jonny
