***Fuel Pressure Riser/Regulator!!!
Old Aug 30, 2001 | 09:02 PM
The Ikon's Avatar
The Ikon
Exclamation
I had a FPR that was a Steve Millen unit in a 300ZX I owned, that was "quoted" 4 or 6 rwhp. For a few bucks it made a difference.
*My question is would a FPR be beneficial to our Lexus vehicles with the finicky ecu in our cars?
*Would it make the car run to lean/rich with the extra fuel?
*How would you run one with an SRT intake/ecu, Weapon-R intake/ecu or Apexi S-AFC w/intake...exhaust? Is it worth the $$$ for the Lexus?
www.weapon-r.com *chose perfmance *then fuel regulator...
www.Stillen.com
Old Aug 31, 2001 | 08:22 AM
The Ikon's Avatar
The Ikon
Question
Any body???
Old Aug 31, 2001 | 10:57 AM
v300's Avatar
v300
Default FPR on a car w/o fuel return
The Ikon,
I am not sure changing the fuel pressure on the 98+ GS would prove 4-6 rwhp. I can tell you that you will run rich especially on a car that doesn't have a fuel return system and an ECU that has volume specific parameters (monitored by hordes of sensors). Honestly, I think you should avoid using a FPR and go directly to A'Pexi or HKS Super AFR, less restrictive intake and bring it to a respectable tuner. I think you might have better luck flooding your engine with a higher output fuel pump.
Old Aug 31, 2001 | 11:03 AM
HKSpowerGS4's Avatar
HKSpowerGS4
A "fuel pressure riser" or and adjustable fuel pressure regulator will not work on the 98+ GS soley for that fact that the fuel system is a returnless system. This means that the fuel pump and fuel pressure regulator is in one assembly in the fuel tank. The fuel pressiure riser/regulators work great for the return systems that have the stock fuel pressure regulator after the fuel rail on the intake manifold.
You will be better off using an electronice fuel adjustment computer to tailor the fuel delivery according to the new air-flow characteristics created by install an intake and exhaust.
BigSticks
Dec 31, 2011 02:35 PM
TIKTIK11
Oct 9, 2001 09:53 PM
Tampa_IS
Performance
Oct 8, 2001 07:02 AM
The Ikon
Aug 31, 2001 08:28 PM
