Excessive steering feedback - SOLVED!!!
Old Feb 8, 2006 | 11:20 AM
lyonkster's Avatar
lyonkster
Default Excessive steering feedback - SOLVED!!!
You might recall my previous thread about feeling excessive steering wheel feedback:
https://www.clublexus.com/forums/sho...d.php?t=196892
Some of you said you felt the same thing, others have not experienced anything like it.
The good news is that I solved the problem, so if this helps any of you, have a read.
I took the car back to the alignment shop, and they swore up and down that it was the wear in the tires that was causing this. I was skeptical (why would worn tires make the car be all over the road?), but followed their advice.
I swapped the worn Dunlop P9000's for a set of Pirelli PZeros, and now... no feedback, no "tramlining", nothing - just a total joy to drive. It tracks straight, it doesn't follow every rut or groove in the pavement, and it does not bounce the steering wheel all the time. And a nice side benefit, the car is infinitely quieter now! Nice to know that the alignment shop was right.
So if any of you are dealing with this phenomenon, don't ignore the obvious thing - the tires!
Leon
Old Feb 8, 2006 | 11:47 AM
jonathancl's Avatar
jonathancl
Interesting. I thought mine had gone away when I replaced my worn Contis with PZeros.
Perhaps that it's returning slowly means it's time for rotation, which is true according to my maintenance schedule.
Old Feb 9, 2006 | 09:01 PM
lyonkster's Avatar
lyonkster
I really hope that those of you who said on my original thread that you experienced the same "tramlining" or unstable steering wheel symptoms as I did got a chance to see this update.
I can now drive the car with just my pinky on the wheel, much better than having both hands clutching the wheel and still being nervous.
And putting on a set of tires sure beats messing with ball joints, bushings, etc .
Good luck!
Leon
Old Feb 10, 2006 | 07:01 AM
Tranman's Avatar
Tranman
Registered User
Yeah, worn down tires will usually do that. There are usually two different rubber levels on tires, the outer "soft" layer...then once it gets near the wear bars, the layer underneath the soft one shows up and it's usually a bit harder, so that's why you get more "feeling."
Old Nov 24, 2019 | 04:39 AM
leadersban's Avatar
leadersban
Default Suffering the Same problem
Hi, I ride 2011 gs450h all the way in South Korea, and I would like to ask you for couple of advices on the issue I'm going through. It seems like the one you had experienced.
In this video clip below, i was driving my car having my hands off the steering. Nothing touched the steering wheel.
All of sudden the steering shifted to the right and my car changed to the lane on the right side as if my car driving on its own.
have you experienced the same symptom ??
https://m.cafe.naver.com/ArticleRead...articleid=5973
Leon[/QUOTE]
AdvanSLF
Suspension and Brakes
Apr 1, 2016 07:48 AM
tlegend
Mar 19, 2010 09:25 AM
supdawg2u
May 8, 2008 05:36 PM
man8959
GX - 1st Gen (2003-2009)
Apr 3, 2006 06:30 PM
hashs99
Jan 12, 2006 06:28 AM
