dash
Old Aug 13, 2001 | 07:00 PM
alkattan's Avatar
alkattan
Unhappy
Will I have around 700 mils on my GS430. On the passenger side I noticed when pressing on the dash, there is a circle hole with no sponge (a size of a finger tip). I am thinking that it will babble up after a period of time. I am not sure what to do since changing the dash will probably not be as good as a factory work because there is a lot to remove. I think the hole is from a babble air that was not noticed after covering the dash with lather. When it is hot in the car and you look closely, you can see a small circle. Yes I am disappointed. I like some feed back, should I leave it till it gets worse, or change it right a way? Not that it is hard to see at this time.
thanks,
alkattan
Old Aug 13, 2001 | 07:10 PM
LexusRules's Avatar
LexusRules
just bring it back to the dealer, just say "what the hell is this" and see what happens, best of luck dude
Old Aug 14, 2001 | 01:56 AM
alkattan's Avatar
alkattan
Default dash
I am getting to think this is normal since you can't see it because if you press around your dash while moving you feel some holes some ware.
Old Aug 14, 2001 | 02:36 AM
Manaray's Avatar
Manaray
exactly where is this happening...I will check on my GS430 to see if it's there...if not, it's definitely a factory defect (or dealer defect) and it'll be covered under warranty...even if they have change the entire dash...
Old Aug 14, 2001 | 06:15 AM
LexusRules's Avatar
LexusRules
so it LOOKS fine? but its just when you press it? i know that our dash kinda spongy (i think its cool) but i've never really felt a hole...
Lammyyy
Nov 1, 2018 05:58 AM
kjv1611
Jul 11, 2014 01:06 PM
Jjman79
Apr 6, 2014 12:45 PM
Briitini
Apr 1, 2013 10:11 AM
alkattan
Oct 2, 2001 02:37 AM
