is this really a $1800 problem
Old Aug 13, 2005 | 12:26 AM
lexus400's Avatar
lexus400
Default is this really a $1800 problem
ok so the light on my instrament panel the one that has to do with the brakes has been on for a while, now when I brake it goes BEEP! coming from under the dashboard every time, and if i keep going everything starts blinking and beeping. so i call up my lexus shop where i get my work done and he says its my abs somthin with the ECU and it will cost 1800 bux
any input would be great
thanks
Matt Cano
Old Aug 13, 2005 | 06:30 AM
3dog's Avatar
3dog
Unhappy warning lights and beeping
Oh man that is a lot of loot. These are great cars, but when something goes wrong it seems like they are very expensive to repair.
Was that a Lexus dealer telling you that?
If you can figure out what part needs replacing you can order it thru one of the Club Lexus venders ie Sewell or Carson and then have someone install it. That would save some money.
ABS is very important and that beeping has got to be awfull. I'm sure someone with more knowledge of brakes will chirp in
Good luck
Ivan
3dog
Old Aug 13, 2005 | 06:41 AM
TLW's Avatar
TLW
please get a second opiniong
chuckb's Avatar
chuckb
like Ivan said, you can probably save hundreds buying the part from Sewell or Carson. It would be worth it even if you have to pay the dealer a diagnostic fee to find out exactly what you need.
Old Aug 13, 2005 | 09:52 AM
chicagoblknazn's Avatar
chicagoblknazn
I agree with Johnny. Have someone else look at it. That's a lot of coin for a lil bit of work.
Old Aug 13, 2005 | 10:00 AM
JacobT's Avatar
JacobT
I had the same problem before. It's the brake master cylinder. Mine was covered under warranty, but I noticed the bill was around $1600
Old Aug 13, 2005 | 10:38 AM
NICKGS4's Avatar
NICKGS4
I had the same problem,ended up being complete brake master cylinder(electronic brake module part of cylinder asy), found a used complete cylinder asy out of a 2000 gs400 for 400.00 and my local lexus dealer actually installed it for 200.00.
Old Aug 13, 2005 | 11:04 AM
blacksc400's Avatar
blacksc400
Car Chat Moderator
There is always cheaper ways to solve problem. Find out the problem and try to locate the parts yourself and just have someone you trust to put in. Dealer always always charge a whole lot.
ESpecially our Fletcher Jones Lexus here.
Old Aug 13, 2005 | 11:35 PM
lexus400's Avatar
lexus400
thanks guys! ill be sure to stick around the forums more often and if anyone needs a sig hit me up
Old Aug 13, 2005 | 11:52 PM
ILOVEGIRLS's Avatar
ILOVEGIRLS
wow.
is this easy to repair as DIY?
Old Aug 14, 2005 | 05:48 AM
TLW's Avatar
TLW
oh really ..hmmm you will have PM very soon from me
Old Aug 14, 2005 | 12:19 PM
Adam2562's Avatar
Adam2562
ask the dealership for a copy of your repair order... legally they have to copy it for you.. and it'll have everything the mechanic wrote down to get replaced..
Old Aug 14, 2005 | 12:33 PM
GS3.0's Avatar
GS3.0
i'll take you up on that offer!
i think its time i got one...pm sent!
Old Aug 14, 2005 | 03:45 PM
ILOVEGIRLS's Avatar
ILOVEGIRLS
where is the master brake cylinder?
Old Aug 15, 2005 | 02:04 PM
Ltech223's Avatar
Ltech223
Default sounded like the master cylinder
If it is the cause. The GS master cylinder is on the driver side up against firewall. Since the master cyliner unit w/ abs system build in one unit. And yes it cost $1800 part alone. Please find a trusted shop to perform this operation. Due to the ABS build in and a special air bleed operation is required.
