differential questions....
Can one of you tell me which, if any, of the lexus models comes with a LSD diff from the factory? I'm tryting to source one that is common with my 97 NA supra
I know the only diff that is unique is the 6 speed in the supra, so I should be ok getting a LSD from another lex/toyota with the same pumpkin. I just need the diff, I will swap my gears, but I don't know enough about the lex's to know which has it from the factory.
Thanks
-M
Thanks
-M
Thanks
-M
Thanks
-M
i know the IS did
but as far as GS's go ...none came with LSD
we usually use the rears from 93-98 automatic TT supras
but some have been using the rears from gs300 in the gs400 but there is no LSD in there
unless you buy it from Kazz or TRD
LS400life
14
Nov 14, 2008 11:56 PM
