Grounding Kit question
Old Jul 8, 2005 | 03:50 PM
DrewGS350's Avatar
DrewGS350
That answers several questions I had. However, one will have to install to truly know if it does make that much of a difference.
Old Jul 12, 2005 | 06:20 PM
Insomnia's Avatar
Insomnia
Finally recieved my Grounding kit today, will be installing it over the weekend. Wanna see how much improvement I get.
Old Jul 13, 2005 | 10:58 AM
jskim9's Avatar
jskim9
Originally Posted by engin_ear
Hope that clears it up for you.
glad someone's an EE major. I guess I just didn't (maybe still don't) see how simply improving current would help a car's performance noticeably. I mean, how much retard is your ignition seeing? Wouldn't the ECU just compensate based on its reading from the O2 sensor? As for the tranny shifting more "precise" as some have said, why would a bad electrical connection make the shifting imprecise? I mean, I understand the degradation of the electrical path over time, but we're talking components that use so little power, compared to a sound system.
I know the difference when there's a poor ground. I used to have my 1500 watt sound system grounded to the car, performance was horrid. Then I grounded the amps individually, directly to the Optima Yellow top, and sudden improvement. But I was drawing over 150 amps. How much juice does an auto tranny need? 5amps at most?
It's just hard to see how such few differences in electrical power and response would matter so much.
Old Jul 13, 2005 | 05:17 PM
engin_ear's Avatar
engin_ear
Everything in Moderation
Based on the explanation I gave above, the problems come in when one device's ground is shifted relative to another's, and this can occur dynamically, based on what currents are flowing where and when. It affects the switching voltages of logic circuits and threshold voltages of analog circuits, both of which are referenced to the individual device's ground. This in turn affects signal timing and levels, and when/what decisions are made. It's almost like if you were to saw your VCR in half and put the control circuits for it in a nearby noisy factory full of electrical equipment while leaving the tape mechanism next to your TV, and run really long wires from one to the other. Nothing is really drawing that much current, but I guarantee you a scheme like that wouldn't work unless drastic measures were taken to connect the grounds, and to keep noise out of the system.
sagikun
Sep 2, 2011 03:32 AM
JDMstatus
GS - 1st Gen (1993-1997)
Nov 9, 2008 01:08 AM
SilverBull
Performance
May 17, 2007 08:27 PM
Concept GS430
Jul 5, 2001 07:32 PM
