Tech Help Needed Please: How to remove trim cover..
Sorry to post in the GS forum but the LS forum is just plain dead when it comes to good technical advice so here's the issue:
2001 LS430, I need to remove the plastic panel that goes around the Navigation Screen. That entire trim peice does Not pull right out. I thought removing it was as simple as the GS (by popping out the ashtray and the center-vents) but there is a trick to this car!
If someone has the manual or access to the Lexus online repair database, can you post the instructions on here?
Thanks!
Thanks!
Blueshark
Jun 13, 2015 08:55 AM
