Tail lights match or not??
I just installed 03 tail lights on my 99 GS400. Is it me or do the inner tail lights not shine the same color as the new outer lights. The reds seem fine when the lights are off but when they are on it seems like the outer lights are a deeper red and the inner lean more towards an orange. Any one else experience this issue?
I decided that I only wanted the inner lights to shine when I press the brake and not when the parking lights are on so I snipped the wire and now it doesn't look as bad.
I originally thought there were 2 ways to fix this problem.
1) buy new inner tail light lamps - 80 bucks from Carson Toyota.
2) buy red colored bulbs to use in inner tail lamps
I suppose if you wanted to avoid the problem altogether you could snip the wire to prevent it from lighting up but that issue of having different shades still exists and - it exists at the most noticeable moment - when you're braking or stopped at a light.
As far as buffing it, that doesn't change the shade of the lens. The lens has actually undergone fading over the course of the years and I think buffing it will - well - make it a shinier faded lens.
I know some of the SC or LS guys are sticking reddish transparent tape over it and although that might work - it just seems tacky. Pun not intended...
Originally Posted by cliffud
I originally thought there were 2 ways to fix this proble.
Thanks for the advice but I fixed the problem. The lenses matched in color except that when the lights were on (parking or brake lights) the inner lamps wouldn't shine a true red so I installed red bulbs and now the match perfectly. I still have them so they only come on with the brakes, they are not part of the parking lights anymore.
Ah ha! I thought that would be a good solution.
Turns out I didn't need the inner tail lights from Carson Toyota. I called up the shop and complained about the tail lights being different colors and they shared those concerns with the insurance company.
1 day later - new tail lights paid for by the insurance company!
Now I can put the old ones into the coffee table! wooooooooooo!
Mayur Patel
Dec 11, 2001 11:22 AM
