Bumper Removal Time
Old Jan 20, 2005 | 11:35 AM
ntran18's Avatar
ntran18
Default Bumper Removal Time
How long does it take to take off and put on the front bumper? More, less, same for both process?
Old Jan 20, 2005 | 11:47 AM
AlphaJZS's Avatar
AlphaJZS
SEARCH SEARCH SEARCH
Removing Front Bumper came up with this
https://www.clublexus.com/forums/sho...g+front+bumper
Old Jan 20, 2005 | 12:09 PM
ntran18's Avatar
ntran18
I did search. Already have directions. Just wanted to get a time estimate of how long it takes to remove it and put it back on.
Old Jan 20, 2005 | 12:13 PM
corkycal's Avatar
corkycal
the first time will always be time consuming. once you do it, the second time will be very fast.
i would say 2 hours for removing and replacing the first time and 1 hour for the second time since you know where every nut is.
the two nuts on each side of the bumper are the hardest to get to.
good luck
Old Jan 20, 2005 | 01:19 PM
ARISTO*7's Avatar
ARISTO*7
good luck
yes the 2 screws on each side is the hardest.. have to go thru the fender wall
Old Jan 20, 2005 | 08:13 PM
chuckb's Avatar
chuckb
Are there any adjustments or is it a straight up bolt on/off? I want a new front bumper soon because my car has a plate frame and we don't need front plates here.
Old Jan 20, 2005 | 09:01 PM
corkycal's Avatar
corkycal
no adjustment needed. when you put your bumper back on, make sure it lines up with the body line. one hand holding the bumper and the other hand tightening the bolts.
Old Jan 20, 2005 | 10:48 PM
rominl's Avatar
rominl
exclusive matchup
first time it took me 30 mins, now i can do it in 10.
hint, you REALLY need the right tool or it will take you a lot longer
Old Feb 15, 2005 | 05:48 PM
TLW's Avatar
TLW
sorry to bump this but what is the right tool ???
Old Feb 15, 2005 | 05:52 PM
AlphaJZS's Avatar
AlphaJZS
screwdriver and a socket wrench 10mm
Old Feb 15, 2005 | 06:02 PM
TLW's Avatar
TLW
oh i know those Panda
i was just figuring from the way HEnry worded it there was some "super"tool
ok thanks
Old Feb 15, 2005 | 06:06 PM
chuckb's Avatar
chuckb
are there any step by step pics of this process?
Old Feb 15, 2005 | 06:16 PM
TLW's Avatar
TLW
ill have one for you this weekend chuck
i have to take off my old to install new
ill do a writeup for 2005
Old Feb 15, 2005 | 06:20 PM
chuckb's Avatar
chuckb
way to be
Old Feb 15, 2005 | 06:33 PM
e-man's Avatar
e-man
Looking forward to it. I'm sure you know this, but those 2 bumper bolts on each side can damage the paint on the front fender if you're not careful. When installing new headlights late last year, Lexus really did a number on my car.
By the way, TLW, thanks for the reply over the weekend on the thread I started for my kids with all the smiley faces. The mods were quick to remove it, but I'm glad someone got a laugh out of it.
e-man
