Shfter Not Shifting
Old Dec 30, 2004 | 12:39 PM
NT2SHBBY's Avatar
NT2SHBBY
Originally Posted by Breakaway
Ok now im almost 100% sure its a wire problem....
Now the sensor on the brake has to be messed up because now when i press the brake on the remote start the engine no longer shuts off like its supposed too... it just keeps on running, so is there a wire sensor on a lexus that may have accidently been cut or a fuse that may have been blown? any help please!!
hold on there buddy....as long as the key is in the ignition-the brake RELEASES the alam and the autostart and of course the car keeps running
the car only shutsdown when there is no key in the ignition and the brake is pressed
Old Dec 30, 2004 | 01:41 PM
Breakaway's Avatar
Breakaway
yes i know that, im talking about when the key is not in the ignition and i press the brake the car does NOT shot off, therefore it has to be a wiring problem because before i ran my power wire thru my drivers side when i pressed the brake the car did shut off.
Old Dec 30, 2004 | 01:49 PM
mikeyboy's Avatar
mikeyboy
i told you, the car is not recognizing the fact that you are pressing the brake. Yes, sure it does still stop when u press the brake but thats besides the point. I told you what you're problem is, if you think otherwise, then i might be wrong
Old Dec 30, 2004 | 02:16 PM
TLW's Avatar
TLW
Have you checked to make sure all your tailights and brakelights are working ???
check
then get back to me
Old Dec 30, 2004 | 02:45 PM
Breakaway's Avatar
Breakaway
no none of the brake lights are working, the circle lights still come on,
As for the wiring problem i understand but i was wondering if anyone had any ideas to what could be wrong
Old Dec 30, 2004 | 02:46 PM
Breakaway's Avatar
Breakaway
Could this be a blown fuse??? i did mess with the fuse box under the hood.. i unscrewed it to have easier acess to run my power wire for the amp
I think it has something to do with the fuses under the hood, becuase the fuses under there are for ABS and the abs light is on in the car, i remember fiddiling with it but i dont know how to check to see if the fuses are blown or not how let me know
Old Dec 30, 2004 | 03:07 PM
TLW's Avatar
TLW
thats why you cant shift
its a safety to let you know that you're brake lights are out
also that why your gauges might NOT be lit another safety
CHECK ALL YOUR FUSES and check all your bulbs
good luck let me know
Old Dec 30, 2004 | 03:11 PM
TLW's Avatar
TLW
you need a light tester ?
to see if they are getting power
just find a good ground and touch the metal on top of the fuse
Old Dec 30, 2004 | 03:57 PM
Breakaway's Avatar
Breakaway
how do i take those fuses out (the ones under the hood)
Old Dec 30, 2004 | 04:14 PM
TLW's Avatar
TLW
when you take off that fuse cover look under it should be ???a fuse grabber and some fuses
Old Dec 31, 2004 | 08:09 AM
TLW's Avatar
TLW
How did you make out ???
Old Dec 31, 2004 | 12:55 PM
Breakaway's Avatar
Breakaway
how do you remove those plastic covers over the fuses?????????????
Old Dec 31, 2004 | 03:41 PM
TLW's Avatar
TLW
Old Dec 31, 2004 | 04:00 PM
TLW's Avatar
TLW
Old Dec 31, 2004 | 04:18 PM
TLW's Avatar
TLW
guys these pics are of the fuse boxes
the one under the dash is where the fuse is for your tails
QCPete
RX - 1st Gen (1999-2003)
39
Oct 14, 2018 02:43 AM
mekelly
Oct 24, 2015 05:29 PM
nevernu
Jan 26, 2014 11:26 AM
EN_VY
Aug 29, 2010 10:54 AM
sergusha
Mar 31, 2004 07:33 AM
