how do i change my headlights
Old Sep 16, 2004 | 11:32 PM
gs3la's Avatar
gs3la
Default how do i change my headlights
does anybody know how to pull out the lights up front from a gs 300? any help would be great. i did a search but no luck.
Old Sep 17, 2004 | 01:26 AM
rominl's Avatar
rominl
exclusive matchup
you need to take off the whole bumper coz' there are couple of screws below the headlight. and then couple of screws above the headlight and you are done
Old Sep 17, 2004 | 03:15 PM
RayGS3's Avatar
RayGS3
If I remember correctly to take the bumper down
there are 4 screws on top, 3 on each side and 10 at the bottom.
Check out BananaGS website.
Thanks to his DIY instruction.
Old Sep 17, 2004 | 03:45 PM
TLW's Avatar
TLW
he is a great man
pretty brave too LOL
for banana
Old Sep 19, 2004 | 12:31 AM
rominl's Avatar
rominl
exclusive matchup
you actually counted the number of screws at the bottom? man amazing, i thought there are like 18384 of them
Old Sep 19, 2004 | 10:08 PM
gs3la's Avatar
gs3la
thanks for the help guys. i meant the actual bulb on a non hid gs300. i tried removing the bulb but it only turns and i cant pull it out. thanks again.
Old Sep 20, 2004 | 01:30 AM
rominl's Avatar
rominl
exclusive matchup
oh man, ws that misleading
anyway, turn the bulb counter clockwise (if you look from behind the headlight) and it should come off. try put in a bit, the rubber might be a bit tough to work with in the beginning
Old Sep 20, 2004 | 11:21 PM
gs3la's Avatar
gs3la
thanks for the help. i'll work on the lights first thing tomorrow. i don't know why but the passenger side bulb turns off once in a while. i thought it had burned out but then i wiggled it and it turned on again. i want to replace both with some high quality bulbs but havent decided on the best bulb for the buck. hey thanks again, especially for the quick reply.
Old Sep 20, 2004 | 11:32 PM
JohnGS4's Avatar
JohnGS4
I had the same problem for quite some time, once you get it loose to where you can move it some, if it's not pulling straight out, try pulling the bottom through first and then wiggling the top through. That worked on mine. Another time, i used a pair of vise grips to pull that damn thing through. THAT WORKED TOO! lol. Wouldn't suggest that method!
John
Old Sep 27, 2004 | 11:25 AM
gs3la's Avatar
gs3la
well thanks for the help but i found out that the problem is the actual harness. i guess the bulbs are too hot for the harness, but anyway i have to replace the harness. probably do this tomorrow. well thatnks again. btw does anyone have a new light bulb they would recommend
mtparker18
Oct 25, 2010 05:51 PM
GSXOTIC
Jan 19, 2005 10:03 PM
DOCGS
Jul 10, 2004 12:41 AM
skins990
Oct 18, 2002 01:15 AM
gsintensive
Apr 23, 2001 11:02 AM
