First mini PC install on a GS?
Old Jul 30, 2004 | 09:54 AM
  #31
CaMsGS3's Avatar
CaMsGS3
aliga - I believe he didnt get the FM tuner installed yet, the unit was on back order..........the reception shouldnt be a problem since you can hook it up to the stock GS antenna
tal - yes with the TV tuner you can only get your locals[2,4,5,7,etc...]
Old Jul 30, 2004 | 01:57 PM
  #32
talgrl626's Avatar
talgrl626
thank you for your update CaMsGS3. this forum is top notch number 1 when comes to friendly aid and solid knowledge
Old Jul 30, 2004 | 02:33 PM
  #33
KVA's Avatar
KVA
Sweet....endless possiblities now... Great install!
Old Jul 30, 2004 | 02:46 PM
  #34
talgrl626's Avatar
talgrl626
isnt' it ?
Old Jul 30, 2004 | 02:53 PM
  #35
RayGS3's Avatar
RayGS3
That's a very NICE set up.
How long did u take to finish the installation?
Old Jul 30, 2004 | 11:15 PM
  #36
asci01's Avatar
asci01
The installation itself took me a weekend. The time consuming part was fabricating the case. It took me a solid week. I only had 1/16" margin of error. but since then I found a metal enclosure at digikey.com that might be a better starting point and cut the case fab time in half.
Old Aug 3, 2004 | 08:02 PM
  #37
core212's Avatar
core212
Lightbulb Custom Dash
I'd like to know how you got that din insert made? the one that holds the monitor... the housing or what have you because i want to do a similar install in my car and don't know how to go about doing the monitor situation. would you please advise on how i can go about doing this? i'm adding a lilliput 7" touchscreen.
i also have a 1998 Lexus GS300...
thanks!
Old Aug 3, 2004 | 08:10 PM
  #38
core212's Avatar
core212
Default Din Insert
Hello,
Just wanted to inquire on how you went about obtaining that din housing for the monitor as i too want to add a touchscreen lilliput into my dash and don't want to go through that whole bondo procedure issue which i'm not too fond about and would like to avoid if possible.
Any information you can give me is greatly accepted and appreciated...
Thank you...
Old Aug 5, 2004 | 02:23 PM
  #39
CaMsGS3's Avatar
CaMsGS3
core - check your PMs
Old Aug 5, 2004 | 03:47 PM
  #40
gabeLex's Avatar
gabeLex
I'm attempting this same project and would like to know about the TouchScreen and Housing. THis would be greatly appreciated. I have a 99 GS300, was thinking to get the LilliPut and somehow mounting, just don't know where to start for the parts. I'm going with a preBuilt Mini ITX CPU, that should fit in the glove compartment. I will post pics to show progress.
Old Aug 5, 2004 | 07:47 PM
  #41
asci01's Avatar
asci01
Send me a PM for details
Old Sep 16, 2005 | 10:06 PM
  #42
RX469's Avatar
RX469
Keep us posted, thanks.
Old Sep 19, 2005 | 06:33 AM
  #43
LEXUS_KID's Avatar
LEXUS_KID
Nice work I like this mod
Old Sep 20, 2005 | 04:09 AM
  #44
aloha08isf's Avatar
aloha08isf
what a great example of "doing it right!"
Old Sep 20, 2005 | 04:25 PM
  #45
asci01's Avatar
asci01
Thanks all !
From the beginning I told myself that I wouldn't do it unless I knew it would look OEM. After I saw the LCD housing done, I knew the project was going to be possible and measure up my high expectations.
