Another rattle found
Old Apr 29, 2004 | 06:30 AM
XYZLexus1's Avatar
XYZLexus1
Default Another rattle found
I was getting another rattle sound and looked for about 8 hours total. I found the heat sheild under the mass air flow sensor vibrating against the exhaust header. The heat sheild is held inplace by three tangs. Two of the three tangs were broken. It is now being held by just the third one. If you have a GS300 check it out. My service advisor was suprised and said he had never seen it before, I find that hard to believe it appears to be a design flaw. It is located on the passenger side of the engine compartment. Follow the air duct to the engine and just prior to the engine you will stumble across a square box, under the box should be a heat shield, if not it has fallen off but the tangs that broke off will still be hanging there.
mljohnson2
GX - 1st Gen (2003-2009)
Aug 8, 2016 07:38 AM
Boasted
IS - 1st Gen (2001-2005)
Jul 29, 2016 12:01 AM
Jz39
IS F (2008-2014)
12
Apr 21, 2016 07:29 PM
933005spd
Sep 8, 2001 09:55 AM
