P0121 code
Old May 14, 2026 | 09:50 PM
3uzchiv's Avatar
3uzchiv
10th Gear
Default P0121 code
I am getting a p0121 on my 02 gs300 and I am wondering what I could do to fix that ? Any tips on what I should check or look for?
Old Jun 1, 2026 | 01:06 PM
CPTSOLO's Avatar
CPTSOLO
Google P0121 shows error code for Throttle Positioner, or system runs too lean, caused by excess air intake.
Could be leaks in the air intake, filter box, hoses, dirty Airflow sensor ect.
What were last last things you did to the car? That may have caused the problems. Look around those areas.
The air filter must be installed properly in the intake box or it may cause a leak. Airbox should be closed tight.
The Airflow sensor may be dirty, needs cleaning with residue-free contact cleaner spray.
Blow smoke in the air intake to find leaks.
Old Jun 1, 2026 | 02:14 PM
3uzchiv's Avatar
3uzchiv
10th Gear
Default P0121
so I changed the throttle body lol becuase it was also not idling or having throttle response much but I still have that code paired with p0120 and p1121 car has cold air intake
OzGs3
Sep 2, 2022 01:33 PM
SCORP69
IS F (2008-2014)
Mar 7, 2019 12:04 PM
Hatchman
RX - 1st Gen (1999-2003)
Jul 14, 2010 04:13 AM
