Beeping noise
Old Oct 27, 2025 | 11:24 PM
sally2004's Avatar
sally2004
2nd gear
Default Beeping noise
So I have a 2000 gs300. In August I had some issues where oil was leaking into my spark plugs and messed up my ignition system. Well I got that repaired for quite a bit of money and haven’t driven much since. The check engine light has come on and off 3 times since the repair but conveniently every time i schedule an appointment it goes off. I have put only 50-100 miles on since the repair. Today as i was driving, a long continuous beeping noise started going along with my whole dashboard lighting up (except the check engine light). I pulled over and turned the car off right away. Realized I had no oil… I filled it just last week and have only driven one mile since. I filled the oil but the beeping wont stop. I am scared to drive it anywhere since I have no idea what is wrong.
So, did the mechanic mess up my repair? Im sure it is the same leak. And can i drive it just a mile to get it back to the mechanic?
Old Oct 28, 2025 | 08:10 PM
TrueGS300's Avatar
TrueGS300
9 times out of 10 a loud beeping from the dash is a failing brake master cylinder in these cars. Do you see an ABS, TRAC, or VSV/VSC type light on?
Old Nov 24, 2025 | 05:42 AM
Tank's Avatar
Tank
A video or some pics would help us try to help you.
DougHousto
Jul 10, 2020 04:10 PM
Eliaquim
Sep 4, 2015 02:06 AM
genin9
RX - 1st Gen (1999-2003)
12
Apr 21, 2015 09:16 AM
99SilvaRX
Jan 31, 2013 01:02 AM
dakamabo
Performance
Dec 11, 2008 02:13 PM
