transmission
Old Feb 20, 2025 | 07:55 PM
nobarzls400's Avatar
nobarzls400
Default transmission
My Lexus Gs430 vibrates up and down when I only reverse at low speed. It doesn't happen when I drive.
Old Feb 20, 2025 | 08:26 PM
JaySco's Avatar
JaySco
Reverse faster.
Old Feb 21, 2025 | 03:52 AM
CarlGS430's Avatar
CarlGS430
Do you mean the whole car moves up and down?
Old Feb 24, 2025 | 02:16 PM
sunpadre's Avatar
sunpadre
Yeah, my 430 does a little shimmer/shake when I slowly back up too - but usually just on hot days. It's been doing that since I took ownership of it 15 years ago. I haven't done anything about it.
Old Feb 24, 2025 | 07:57 PM
DanielleAlek's Avatar
DanielleAlek
Transmission mount/engine mounts, most likely. Reverse gears are cut differently than the rest of your gears, so a lot of the time, the car will shake differently or more in reverse, making it more noticeable. Same reason the steering wheel is dead still in park, but might have more vibrations in drive. As long as it's not accompanied by a rough idle, you should be fine.
If it's been 15 years and that's the only issue to do with shaking/rattling, you're doing pretty good.
mej
Aug 13, 2024 09:54 AM
Ekul61
ES - 7th Gen (2019-2025)
20
Dec 27, 2023 03:26 PM
Scraape
Jul 22, 2020 06:11 AM
YogiFTLC
Sep 3, 2017 02:38 AM
