Power steering
Old Nov 1, 2024 | 10:29 PM
430gs's Avatar
430gs
6th Gear
Default Power steering
what up y'all I just bought a 2001 gs430 & was told NOT to put normal power steering because it will blow the pump, instead they told me to use tranny fluid.
Can I get some feedback on this please.
-josh
Old Nov 1, 2024 | 10:46 PM
That is correct the power steering system uses Dexron II/III (or equivalent) automatic transmission fluid.
Old Nov 1, 2024 | 11:11 PM
Oro's Avatar
Oro
Yep, what he said, and it SHOULD say that right on the cap - our 02 does IIRC.
Regular ps fluid should not blow it, but there is not a single reason to use it over the cheaper and recommended DexIII.
Old Nov 2, 2024 | 04:57 PM
430gs's Avatar
430gs
6th Gear
good lookinout brother
Old Nov 23, 2024 | 10:54 PM
dwoods801's Avatar
dwoods801
One of the most common issues with these vehicles is the power steering pumps leaking fluid into the alternator. So you will have to keep topping off the fluid, and eventually the alternator will go bad. Or you can rebuild/replace the PS Pump, and any bad PS hoses and get ahead of the issues.
Old Dec 4, 2024 | 09:05 PM
PeytonWalker's Avatar
PeytonWalker
1st Gear
I had the same issue, How is everything now?
Spoiler
ComponY
GS - 1st Gen (1993-1997)
Aug 18, 2014 08:22 AM
cgreenberg
Oct 6, 2010 06:27 PM
SC_Edgar
Jul 31, 2009 12:19 PM
pepperochi
Jul 18, 2008 10:28 PM
Belement
May 19, 2008 04:47 PM
