EVAP Code
Code: P0440, P0441, and P0446
Pass emission except for check engine. (I also learned that these codes are about vacuum seal issues.)
I tried searching online and found that there is 2 valve vacuum switch, one on the engine bay and one by the evap canister.
Near Engine bay: https://parts.parkplacelexusplano.co...091012188.html
Near EVAP Canister: https://www.partsgeek.com/catalog/20..._solenoid.html
I'm asking for advice, should I check the engine bay vacuum switch first, see if its working then work on the canister, or should I check for any leaks (i dont have a smoke machine, and it seems expensive online, if there is one cheap, can you link it?), then check engine valve, then canister?
If you have any other ways to fix/help let me know, thanks!
Max Power
Sep 14, 2010 04:15 AM
