A/C Codes
Old Mar 15, 2023 | 01:51 PM
unkonat's Avatar
unkonat
10th Gear
Default A/C Codes
How’s it going guys, just had a few questions. My ac blows warm, the ac light blinks. I got two stores codes 21 cause i’m in my garage and 24 but i can’t seem to find anything on 24. Both codes go away when i drive out of my garage into the sun but when i turn the ac on the light just blinks and doesn’t blow cold still. when i press the ac button my rpms jump up and goes back down shortly after. i have freon and my compressor relay is brand new. Any thoughts/tips? lmk thanks 🤙🏽
Old Mar 15, 2023 | 04:51 PM
Arsenii's Avatar
Arsenii
Hello,
What brand clutch did you use?
The clutch is supposed to come with adjustment shims, did you adjust the gap of the clutch when it's released?
Code 24 is essentially the same thing as Code 21, but for the Passenger side, so it is safe to disregard as well.
Blinking Light usually means some major failure in the system, like no refrigerant in the system, or a locked up compressor. You mentioned installing new clutch on it, if it wasn't adjusted correctly, there is a chance it doesn't engage, or is rubbing when it is not supposed to be engaged, causing the system to fault. There is also a Compressor Lock-Up Sensor, essentially the same as a Crank Sensor, it counts the amount of RPM of the compressor to tell if it is locked up and disengage it before causing any further damage to the compressor or the drive belt, and its code is pretty difficult to trigger, here is a thread of that subject.
Hope this helps and best of luck!
KyleH
Sep 26, 2022 08:29 PM
jadesc4
May 23, 2022 08:09 PM
Dlogvine
Aug 18, 2020 04:22 PM
ceephis
Aug 21, 2017 03:36 AM
sub786sub
Jun 14, 2007 07:56 AM
