A/C light blinking
Old Sep 25, 2022 | 09:39 AM
Gensc300's Avatar
Gensc300
Default A/C light blinking
A/c blows cold after new compressor, but turns off shortly after button is pressed? Relat checked out good aswell. Only thing i can think off is maybe pressure switch is faulty???
Old Sep 26, 2022 | 12:25 AM
Arsenii's Avatar
Arsenii
Hello,
The issue you have sounds a lot like the one described in this thread, where a person got a faulty Lock-Up sensor with a new compressor. That sensor sends out an RPM signal, so that the ECU can detect if the compressor got jammed and disconnect it, preventing it from chewing the drive belt and leaving you stranded in a middle of nowhere.
Start by checking the fault codes stored in the system, as it is described in the thread above, which should still be valid for your car. If you come up empty, check if there is any signal on the Lock-Up Sensor, if not, then there is your issue.
Hope this helps and best of luck!
Old Sep 27, 2022 | 12:19 AM
Gensc300's Avatar
Gensc300
Originally Posted by Arsenii
Hello,
thanks for the good info i will test this as soon as possible.
cgreenberg
Apr 23, 2024 07:11 AM
mroctober7
May 20, 2020 09:26 AM
Alanbama
May 26, 2014 05:47 PM
snidehocke
Jan 29, 2008 05:20 AM
JCW
Lighting
Mar 3, 2006 07:41 PM
