Need helpppp!!!!!
Old Sep 25, 2022 | 09:26 AM
jzsstan's Avatar
jzsstan
4th Gear
Default Need helpppp!!!!!
my 1994 lexus gs300 is idling at 2-300 rpm. i just did valve cover gaskets and it ran perfectly before. got new plugs and wires runs better then before perfectly fine at anything above 1500rpm anyone have any idea what the cause might be?
Old Sep 25, 2022 | 09:46 AM
lexo98's Avatar
lexo98
It’s been a while since I worked on that engine but what did you have to remove to get to the valve covers. Vacuum leak?
Old Sep 25, 2022 | 09:49 AM
jzsstan's Avatar
jzsstan
4th Gear
had to pull the whole intake plenum off to get to the valve covers and i thought vacuum leak but my last gs had a vaccuum leak n it idled at 800 ran fine also i checked for it didnt find anything
Old Sep 25, 2022 | 10:25 AM
lexo98's Avatar
lexo98
You can try to disconnect the battery so that the system can relearn but I really think you have a vacuum leak. Spray some water around the connections and see if you can hear it
Old Sep 25, 2022 | 10:27 AM
jzsstan's Avatar
jzsstan
4th Gear
okay ill try that when im off work
Old Sep 27, 2022 | 11:44 AM
jzsstan's Avatar
jzsstan
4th Gear
didn't find any vacuum leaks was talking to someone and they said try and clean the iac and see if that fixes it
Old Jan 2, 2023 | 07:42 AM
TOYOTA2JZ's Avatar
TOYOTA2JZ
5th Gear
Kinda late to the game here, but I’ve always used carb cleaner to look for vacuum leaks. Spray it around parts you had removed, if the idle goes up you found the leak. Obviously avoid spraying into the intake filter as that will always idle the engine up.
Old Feb 21, 2023 | 07:57 AM
paulpiker's Avatar
paulpiker
6th Gear
same thing i used to use carb cleaner , you should try it
Pjx
Mar 19, 2020 11:22 AM
Doneve79
Dec 19, 2016 07:39 PM
rah74
May 8, 2016 09:14 AM
GregZ1969
Apr 17, 2013 09:04 PM
dsisoutham
Mar 25, 2013 06:52 AM
