radiator hoses
Old Jul 10, 2003 | 12:36 PM
indypwr's Avatar
indypwr
Default radiator hoses
anyone here has tried changing the upper and lower radiator hoses?
since i have over 125000 miles, im thinking of changing them and most likely change
the thermostat also. im plnning to buy the TRD thermostat from carson toyota this wknd.
i hear good things about it. it helps temperature to run a little cooler of the car by opening
of the thermostat a bit early and letting the coolant flow.
Old Jul 10, 2003 | 04:07 PM
LB Lex's Avatar
LB Lex
I add Redline Water Wetter to my cooling system, it lowers the temperature by 10-15 degrees. I've been using this stuff on my other cars for the last 10 years and it keeps my cars running cooler. I also use 25% antifreeze instead of 50% because it helps keep my car a little cooler too.
Oh, changing the radiator hoses is pretty easy, just unclamp the old ones and then clamp on the new ones. Changing the hoses on a car that has over 100k miles is good preventative maintainance because the hoses get old over time and it is hard to tell if it is about to burst.
Old Jul 10, 2003 | 10:51 PM
indypwr's Avatar
indypwr
yo, eric...tks for good advice.........where can i get this redline stuff??>..and how much?
Old Jul 10, 2003 | 11:37 PM
LB Lex's Avatar
LB Lex
Pep-Boys, it's around $6.
Old Jul 11, 2003 | 03:03 PM
indypwr's Avatar
indypwr
ok....tks. ill go buy one today while i pick up my radiator hose frm the dealer.
how much redline coolant shud i put or mix with water?
Old Jul 11, 2003 | 05:26 PM
LB Lex's Avatar
LB Lex
the whole bottle.
Old Jul 11, 2003 | 10:52 PM
indypwr's Avatar
indypwr
tks buddy...
so, did you put those fogs yet? are thy working good? how about the bulbs? did thy even lit up?
Old Jul 11, 2003 | 11:00 PM
LB Lex's Avatar
LB Lex
I put on the foglights when I got home the night I bought them from you. They are working well, I just have to adjust the aim of my headlights & foglights so they cover as much of the road as possible.
lexixel
Feb 1, 2016 11:22 AM
lexus-is2
Apr 7, 2014 05:40 AM
khailon
Mar 2, 2011 08:14 PM
ClaudiG
May 25, 2006 09:12 PM
