BMW 740i 6speed manual transmission
Hi guys
have anyone slapped a BMW 6speed transmission at the back of a 2jzgte? I've been researching this for my gs. Everything information wise looks good, but I came across a post somewhere, somebody said the BMW transmission gear ratios with the combination of a Supra differential wouldn't be worth the try as you will have to start in 2nd gear all the time. Unfortunately I can't find the thread at the moment:/. But any inputs?
I did a quick search and found a few kits that would adapt a BMW Getreg trans to a 2JZ and I also found a pretty long post about here on Clublexus.com here is a link.
https://www.clublexus.com/forums/performance-and-maintenance/757608-bmw-gearbox-2jz-anyone-stateside-done-this-yet.htm
https://www.clublexus.com/forums/per...e-this-yet.htm
I'm doing a Nissan 350Z CD009 6 speed manual transmission swap right now. You can get an adapter plate from 2 different vendors. I chose Maverick Motorsports and got the twin plate clutch setup. The clutches, flywheel, pressure, adapter, all bolts etc were $2,025. The CD009 transmission used was only $850 shipped to my door. I had to buy the shifter bracket and assembly for $125 as well. Next, I need to buy a clutch pedal, line and master cylinder, drill a hole in the firewall and mount it all.
05-06-17 12:30 AM
