Cold Start Issue
Old May 8, 2014 | 06:44 PM
KevinBogle's Avatar
KevinBogle
Default Cold Start Issue
In the morning or after a several hour rest my 1995 GS300 will not start on first attempt just cranks or if it does start it runs rough for a few seconds only to die. I turn the ignition off then re-attempt and it starts right up and runs like a champ every time. Ideas on my problem???
Old May 8, 2014 | 07:04 PM
2jKarma's Avatar
2jKarma
New battery helped mine on that problem and thinner oil but then again I had a tune up done as well all on the same day I would check the battery , starter etc also check for exposed wires! Major issue with my gs3
Old May 8, 2014 | 08:40 PM
Nixspeed's Avatar
Nixspeed
Low battery voltage is a very good possibility. Also a tune up should help as well I'm sure. Another common issue is the coolant temp sensors.
Old May 9, 2014 | 03:28 PM
kene's Avatar
kene
mine does the same. started a little over a month ago. I have a code 71 for EGR and a knock sensor code (code 24? or 22?...dont remember)
2Jkarma and Kevin Bogle, could you guys check for any codes. if we all have the knock sensor code come up, then maybe that is what the problem is. I have 2 new knock sensors, but I would hate to install them, and find out that is not the issue.
Could be my battery as it has been died 2 times in the last 2 weeks, but it is a 2 month old, brand new, optima yellow top.
If there are no codes for you guys, then maybe it is the battery.
If any one finds out please let us know.
Thanks
calteg
IS F (2008-2014)
14
Feb 16, 2015 11:01 AM
mk4r34
Oct 22, 2012 08:44 AM
LudeNsoL
Mar 6, 2012 08:24 AM
vietpr1nce
May 17, 2009 03:19 PM
Handogen
RX - 1st Gen (1999-2003)
Sep 30, 2004 01:19 PM
