Obd Ii ???
first gen guys,
i was wondering if you know if the 93 gs is OBD II. my buddy's gs has a check engine light on and i'm thinking of pluggin in my reader to check it out for him. i need to know if there is a connector of the first gen gs and where it's located if there is one. thanks.
Originally posted by gompka
this is the site that tells you how to retrieve the codes without using a scan tool. LINK
Thanks for the info....
By the way do you or anyone know how to reset the airbag warning light on the instrument panel? Mine is on but the system is not malfunctioning. It has done this before when i mistakenly removed the fuse for that function but i had it cleared during a service i had done at a mechanic's shop but they charged me $40 and wouldnt tell me how they did it...(no **** huh) but they did state it was somewhat involved. He checked the code first and it read that the instrument panel had been removed that's why airbag light was on. Well, i did remove the instrument panel, to install part of my woodgrain kit which covers the instrument panel but is behind the clear plastic. Will resetting the codes correct this? or do i need to do something else?
mbrown1782
Feb 6, 2013 03:11 PM
