MAF Sensor Voltage Range
Old Mar 19, 2013 | 12:32 PM
Beerguy's Avatar
Beerguy
Default MAF Sensor Voltage Range
Hi
Does anyone know what the expected voltage range output from the MAF sensor would be on my 1993 GS300? I need to test it and see what it kicks out. I know there are expected ranges at idle and certain RPMs, and if it does not produce the sensor is considered bad, but I can find out what the spec is. I would certainly appreciate any help.
Thanks
Jeff
Old Mar 19, 2013 | 10:53 PM
TheMole's Avatar
TheMole
Here you go:
1.Disconnect the Volume Air Flow Meter connector.
2.Using an ohmmeter, measure the resistance between terminals THA and E2.
10 - 20 k ohms at -20°C (-4°F)
4 - 7 k ohms at 0°C (32°F)
2 - 3 k ohms at 20°C (68°F)
0.9 - 1.3 k ohms at 40°C (104°F)
0.4 - 0.7 k ohms at 60°C (140°F)
If the resistance is not as specified, replace the Volume Air Flow Meter.
3.Reconnect the Volume Air Flow Meter connector.
Old Mar 25, 2013 | 09:14 AM
Beerguy's Avatar
Beerguy
Default Thank you!
Thank you Mole, I appreciate the response. In the meantime, I was able to locate a very well detailed test procedure that used my exact sensor as a test case
http://easyautodiagnostics.com/111/M...009b1-MAF.html
Thank you for you help!
Jeff
Old Mar 25, 2013 | 08:57 PM
TheMole's Avatar
TheMole
Jeff
No prob man, good info in that link!
dice66111
Dec 22, 2021 01:33 PM
lexus-is2
Mar 26, 2013 07:12 PM
valikaaar
Nov 21, 2011 07:18 PM
UberNoob
Maintenance
Aug 27, 2008 05:35 AM
sbm is300
RX - 1st Gen (1999-2003)
Jul 24, 2006 07:36 PM
