headlight and fog light project
so i got to do my headlights clear n polish them to look brand new n i really impressed myself ,so i took my fogs out n open them up n retro fit some 95 es300 yellow fog light projectors nnot to bad to say ,i will being doing a write up on the fog light retro fit soon ..
,to make them look nice and new i wet sand the lens with a fine 1000 grit sand paper and then a finer paper 1500 grit then i high speed polish the lens with compound and then high speed again with a glaze polish then wax them and they should be nice and new ,to clear them i un screwed the screw that holds the amber piece to the inside the lens then i just broke the amber piece into little pieces and remove ,i also made the high beam light yellow buy coloring the bulb with a yellow sharpie save me about 30bucks on some e bay high beam lights buy a little trick i learned,with the fogs i took the lens off with a heat gun retro fit some 95 es300 yellow fogs in the housing of the gs300 fogs ,u have to disassemble the es300 fogs n use only the fog projector only ,i used some washers n screws and i resealed them with a seam sealer we use in our body shop.hope i explained it well enough ,hope to see some one try a retro fit like this on the fogs,pics soon of the light up on the fogs thanks cl
Do you still have the regular fogs from the lexus gs? I wasn't quiet sure if you did haha. And Instead of waxing it, could i just spray clear coat right after it was hazing?
if u want to clear the head lights u have to sand them in 600 grit and then clear them n them wet sand and buff them ,ya i still have the interior of the fogs they put in my storage,those that u see in the pics are the orginal fogs but just with 95 es300 projector fog retro fitted into them
greens14
SC400 / 300 Classifieds
03-01-12 12:03 AM
UberNoob
06-20-07 02:14 AM
kgh31386
IS - 1st Gen (2001-2005)
02-22-06 01:58 PM
