AC temp control problems
Old Sep 29, 2012 | 03:37 AM
gssteve's Avatar
gssteve
Default AC temp control problems
I have a 93 gs300 and when I set my ac temp to 65 it works great but it gets freaking cold after a bit so when I try turning up the temp as soon as I hit 67 or above the AC light turns off and the fresh air lights up and it just blows hot air. I can turn the ac button back on but the temp stays hot until I go back down to 65 degrees. Every blue moon it will work and I can adjust it up to 70 and it works but that is on a very rare ocassion. Any help would be great bc the GF hates being froze or just hot lol.
Old Sep 29, 2012 | 09:04 AM
JamPatGS's Avatar
JamPatGS
There is a sensor behind the driver side front bumper reinforcement that read outside temperature and if unplugged it will only give cold a/c at 65, anything above the heater kicks in... maybe yours is defective or not fully connected..
Old Oct 1, 2012 | 06:22 PM
gssteve's Avatar
gssteve
Ok that could be my problem because the PO did a 2gen front clip conversion. Do you have a picture or anything so I can verify if I have it or not. I know for sure it's not working bc my outside temp reading is -22..
Old Oct 2, 2012 | 07:43 AM
m1k3yg's Avatar
m1k3yg
I know this has nothing to do with your problem but PLEASE! Post pictures of your car I always wanted to see this conversion done
Old Oct 3, 2012 | 02:21 PM
yangaroni's Avatar
yangaroni
i need to know where this wire is because i think i have the same problem
Old Oct 3, 2012 | 06:58 PM
gssteve's Avatar
gssteve
after plasti dipping the rims
Old Oct 3, 2012 | 07:48 PM
Boosted1st's Avatar
Boosted1st
I also have this same issue, I know my front bumper has been replaced...so I need to hook this back up as well. A picture of it's location would be fantastic.
Old Oct 3, 2012 | 08:39 PM
TheMole's Avatar
TheMole
Wow can hardly tell its a 1GS!
Old Oct 5, 2012 | 07:58 AM
JamPatGS's Avatar
JamPatGS
Ill take a pic tonight of the sensor, but if i remember its behind the driver headlight attach to the bumper reinforcement
UncleRico
GX - 1st Gen (2003-2009)
Jun 21, 2019 04:26 PM
svlexus
Mar 28, 2011 07:47 AM
cutecboy
Oct 19, 2002 09:13 PM
