Fog Light removal help
So a couple of months back, the left fog light stopped working or it hasn't been working. I don't know i just noticed it back then but never bothered to check. So yesterday, I tried to remove the fog light but i couldn't get the grey plastic part to come off so i accidentally broke it..
If there is a way to getting this off can someone show me a guide thanks! okay, Now to the fog light part, I removed the fog light and i looked at the wiring. It doesn't look like it's connected right because the ground looks like its connected to the positive wire. Not sure if that's how it is but seems wrong to me.
I've tried pulling it off for 10-15 minutes without any results I can't seem to be able to split apart the thing that's holding the wires.
(The black thing in the middle of the wires) Not sure if it's removable but if it is, can someone show me how? thanks!
Just a thought but incandescent bulbs are non directional in terms of which side receives power and ground. Although they should be hooked up a certain way I don't think it matters. I haven't depinned one of those connectors so I'm not sure on how to do those BUT if u can't figure it out you can swap the connection Inside te housing. They're just female spades.
