help
Old Dec 20, 2011 | 10:39 PM
frayko's Avatar
frayko
Default help
i have a 1998 lexus gs300, when ever i am sitting idle the car acts like it wants to shut off, it putters, at times it does shut off, this only happens when i am sitting idle in the drive or reverse gear, when in neutral its ok. after take off the car drives normal. i used a diagnostic machine and the code i get is p1349 vvt malfunction. I have had three different explainations for this. 1) i need a new coil, car has 3 but one may be misfiring 2) solenoid needs replacement 3) valve cover needs replacement so far i have changed the oil and spark plugs
Old Dec 21, 2011 | 07:10 PM
supra247's Avatar
supra247
wrong section, 98 is 2nd gen.
p1349 is vvti code, most likely the vvti oil passage is blocked. run some atf in your motor for a few minutes and that should unblock it.
UNOCAM
IS - 1st Gen (2001-2005)
Mar 15, 2017 09:16 AM
joshuag8
Dec 1, 2011 08:38 PM
02msmg3
Performance
Nov 27, 2010 02:54 PM
Siklex9816
Feb 20, 2009 10:44 PM
