Another overheating thread
Old Jun 4, 2011 | 06:22 PM
kwikracer's Avatar
kwikracer
It seems you were right kene it does seem to go to the throttle body. Is this a cut to fit hose or do I need a special hose? What all do I have to remove to swap it out it seems like quite a bit just to replace that darn hose.
Old Jun 6, 2011 | 06:16 AM
kene's Avatar
kene
you should be able to find a cut to fit hose at your local pepboys(the rubber hose supplier for the autozone's here in CA are in a shortage, I went to 4 local autozones here in So-Cal and they all said the same thing. Someone made a massive spot purchase on certain sized hoses and the manufacturer is behind in stock) that has the matching inside diameter and hose clamp.(your stock clamp may or may not work on this new hose.)
Old Jun 6, 2011 | 06:26 AM
USMCgs3's Avatar
USMCgs3
Some people take the throttle body off to get to the hose, but get a long curved pair of needle nose pliers and you can get it off both ends relatively easy.
Old Jun 7, 2011 | 08:00 AM
Diemellz's Avatar
Diemellz
Originally Posted by kwikracer
Haven't found the issue yet, im a huge procrastinator. Hopefully I'll change the hose tomorrow and take it for a test drive.
make sure u double check the Radiator, i found a crack in mines, at the very top where u pure coolant in it, easy to miss without a funnel
Old Oct 9, 2011 | 12:01 AM
kwikracer's Avatar
kwikracer
Well it turns out it was my water pump. Shortly after it started leaking water through the weep hole so I replaced the water pump and the timing belt. $230 parts and labor at a shop.
Old Oct 9, 2011 | 07:51 AM
greens14's Avatar
greens14
Wow! how'd you make it driving around that long like this? or is this not your daily?
Old Oct 9, 2011 | 10:40 AM
kwikracer's Avatar
kwikracer
Well it is my daily driver but I didnt have money to fix it so I had to drive my gas guzzler 98 BMW 740il.
Old Oct 10, 2011 | 09:24 PM
buckwheat's Avatar
buckwheat
sorry to jump on your thread but I'm also having exhaust coming out my radiator and it started before i replaced the head gasket from an mk4 new gasket not used i also redecked the head and after putting it all back together I'm still getting the exhaust coming out my radiator any idea ?
1kingslimg
Feb 5, 2015 07:33 PM
93lexusLS
Nov 17, 2013 06:57 PM
cheramiear
Aug 24, 2012 10:08 PM
habdelr
13
Oct 3, 2007 11:12 AM
lykdatyall
Sep 5, 2007 06:59 PM
