Help!!!!
Old May 26, 2010 | 06:41 PM
RedSC's Avatar
RedSC
Default Help!!!!
Okay in an attemp to fix my temperature needel on my gauge cluster now its not moving at all, I tried swapping it for another one by pulling out and the putting the other one in. I then figured out that the other one didn't work either so I put back the original one but now its not working help plzzzz
Old May 26, 2010 | 07:08 PM
mkiiisupra's Avatar
mkiiisupra
well you didnt mention anything about loosening the circuit boards, but when I changed my LED's, I didnt tighten the screws all the way and the needle worked on and off. Took the cluster back out and realized I forgot a couple, tightened them up, and it worked.
May have nothing to do with your issue but if you have nothing to do, only take a couple minutes to find out
Old May 26, 2010 | 09:58 PM
VIP_Dreamz's Avatar
VIP_Dreamz
don't over tighten the needles. sometimes if you, the needle gets stuck. when you put the needle on move it with your hand and see if it sweeps left and right by itself.
Old May 27, 2010 | 01:13 AM
RedSC's Avatar
RedSC
Default car
yeah ill try doing that tomorrow morning because i might of done that thanks
boohunlove
May 12, 2018 08:56 AM
boostvic
Sep 6, 2013 01:57 PM
sandro147
Jun 10, 2012 11:12 PM
Emilio253
Dec 16, 2010 05:00 PM
redhanded7
Dec 10, 2007 10:26 PM
