Supra Brakes...Finally
Old 07-14-09, 05:10 PM
PWidow
PWidow's Avatar
Originally Posted by Lexatlast
Pwidow, i'm not gonna lie, i've looked at these pictures about 10 times today and i take in a deep breath and pull my stomach in every time i see that clearance... jesus, its sooo close. Did you know it would be that close? and is the clearance that tiny on the rears as well? can't tell from the pics.
and lastly, if the offset were +38-+40 in the front, do you know if the brakes fit?
Yes I actually did know they were going to be that close, that was the hold up for a few weeks till I decided what to do. When I test fit them, they didn't work so I even thought about getting new wheels at the time, but I had to make them work So I had to grind on the caliper just a little bit and then use a 3/16" spacer and then get extended studs to make everything work. No the rears bolted on with no problem and I still have probably about 1" gap between the wheel and the caliper.
And like mkiiisupra said, it will all depend on the wheel. The way my spokes are curved made them not work...at first
Old 05-30-12, 09:46 PM
CHIKARA
CHIKARA's Avatar
Default Parts needs
Do you just need rotors, calipers, brakeline, and pads. To bolt on.???
Old 05-30-12, 10:38 PM
mkiiisupra
mkiiisupra's Avatar
will also need assembly kit (rods,spring)
https://www.clublexus.com/forums/gs-...ls400-bbs.html
Club Lexus Editor
08-10-16 03:06 PM
iasc300
SC- 1st Gen (1992-2000)
14
12-03-09 05:55 PM
ek9vboi
Florida Lexus Club
29
07-21-09 03:12 PM
exvelocity
11-13-08 11:05 AM
Juangado
NELOC
16
06-23-08 06:28 AM
Quick Reply: Supra Brakes...Finally
