Electrical Issue, please advise
Old Mar 25, 2009 | 10:51 AM
gs300_tx's Avatar
gs300_tx
Default Electrical Issue, please advise
Hey guys, been a member here for a while, first time posting.
I have a 1995 Lexus Gs300, and I have been having a weird issue, which involves the Telescopic Steering wheel control to stop working, and the radio(goes out), the clock and the trip odometer to reset by it self. I checked the fuses but they seem to be fine.
The problem seems to go away on its own, but keeps coming back. What do you guys think it could be? Any help is appreciated.
Thanks
Old Mar 25, 2009 | 11:15 AM
jmax.garage's Avatar
jmax.garage
short on the ignition switch or in the plug... check for packrats too!!
Old Mar 25, 2009 | 12:19 PM
gs300_tx's Avatar
gs300_tx
if there is a short on the ignition switch, should the radio and clock and the trip odometer have reset it self while driving?
what are packrats?
Thanks
Old Mar 25, 2009 | 03:02 PM
CopperShot's Avatar
CopperShot
Check your main ground cable, usually those get corroded quick and over time.
Old Mar 25, 2009 | 04:15 PM
gs300_tx's Avatar
gs300_tx
Thanks,
Where can I find the main ground cable?
Old Mar 29, 2009 | 07:38 PM
CopperShot's Avatar
CopperShot
I'm not POSITIVE, but follow the negative cable to a point on your chassis.
I'll double check for you. Have to look through schematics.
Old Apr 14, 2009 | 03:27 PM
gs300_tx's Avatar
gs300_tx
Hey guys, someone just told me about this but I don't know how true it is.
About a month before this started happening, i had replaced my cd player and come to find out the wiring harness that was used for the previous installation was alll jacked up. Is it possible that some wires are touching back there that is causing this to happen?
Thanks
Old Apr 14, 2009 | 06:23 PM
SNFL's Avatar
SNFL
I had this problem before on a nissan, it ended up being the ground cable. Might want to check that like CopperShot said. But I am not 100% either on this particular car.
Old Apr 14, 2009 | 06:33 PM
dorimon's Avatar
dorimon
i had the same problem not too long ago. I replaced the ground with no more electrical problems.
Old Apr 14, 2009 | 06:35 PM
gs300_tx's Avatar
gs300_tx
Where can I find the ground cable?
Thanks
Old Apr 15, 2009 | 01:00 AM
vindedreal's Avatar
vindedreal
Yeah I also have a short (Something touching the ground) , i Cant seem to locate it
Old Apr 15, 2009 | 08:12 PM
plkyone's Avatar
plkyone
i have seen this problem with the ignition switch especially if you have a ton of key's along with you car keys the extra weight tends to wear the cylinder
Old Apr 17, 2009 | 09:14 AM
gs300_tx's Avatar
gs300_tx
Just so I understand this right, because of the ignition switch, my radio, interior lights, clock, trip odometer, and telescopic streering wheel would stop working?
About a month ago I had a new cd player installed and the wiring in the back was allll messed up. Could it be because i need a new wiring harness?
thanks
Old Apr 20, 2009 | 12:21 PM
gs300_tx's Avatar
gs300_tx
Does any one know where I can find the ground cable on our cars?
Thanks
Old Apr 20, 2009 | 09:01 PM
GS300ZX's Avatar
GS300ZX
follow it from the battery, but it grounds to the chasis down low near the ac compressor and then continues to the engine.
