Starter Problem and Location?
Old Dec 5, 2008 | 03:44 PM
Gs 702's Avatar
Gs 702
Default Starter Problem and Location?
I have a 1993 Lexus Gs300 and i have a problem starting my car. At first the terminals on the battery were bad so i had to replace them with new ones. When i try to start my engine, it makes a single click. All my electronics work fine and its a new battery. Can anyone tell me the location of the starter with pictures if you could? Thanks.
Old Dec 6, 2008 | 12:55 AM
94vteg's Avatar
94vteg
good luck with this one, i just replaced myne 3 months ago it was PURE HELL ,well anyway its underneath the intake manifold on the bottom but i manged to get iy out fronm the bottom oh did i mention it was a nightmare
well anyway good luck with it and yes that is your starter thats making the single click its the solenoid inside
Old Dec 6, 2008 | 08:24 AM
dario's Avatar
dario
Well if you are asking WHERE the starter is then you should not get it replacedby yourself it is a big task on this car and not even knowing where it is is much smaller task than actually replacing it.
Old Dec 7, 2008 | 05:08 PM
bigdogg49's Avatar
bigdogg49
it is on the driver side and is easier to get to from underneath if you use a really long extension for the top bolt, it isnt that bad, unless it doesnt want to break loose, but the long extension helps alot!!!
Old Dec 8, 2008 | 06:24 AM
mkiiisupra's Avatar
mkiiisupra
Like big dogg said. Its under the intake mani and you'll want to remove it from the underside of the car. The bottom bolt you'll be able to get to just fine but the upper one is hidden. You will need about 3 extensions and a universal socket to get it. You'll have to go up and over the bell housing with the extensions and feel around for the bolt head. Its not the most obvious strategy but its the easiest. The only hard part is holding the starter in place with one hand while trying to get the bolt back in with the other, referring to the bottom one which you'll want to put back in first when installing the new starter.
Kalogerus
Feb 4, 2012 02:05 PM
atxzenki
Dec 6, 2010 04:41 PM
kenatl06gs
Aug 30, 2010 09:06 AM
Craig7022
Aug 8, 2007 02:57 AM
Dx3
Oct 14, 2004 10:40 PM
