5 speed Aristo Swap Almost Done
Old 02-14-08, 09:46 PM
  #61
yesca
yesca's Avatar
Originally Posted by jayzsun
your car is sick. throwin nice smoke. anyway,
i had a question, is that a r154 from the 1jz or mkiii? also what trans mount did you use. any help would be appreciated. thanks
Thanks...The tranny is a r154 from a chaser jzx90
Old 02-14-08, 11:53 PM
  #62
status....
status....'s Avatar
Originally Posted by yesca
I still have it. PM me your number and we can talk
soots man, pm sent
Old 02-22-08, 10:56 AM
  #63
SuprRunner
SuprRunner's Avatar
Ok man, I ordered a wilwood reverse swing pedal, but I have a problem. It is a dual cylinder and uses a balance bar. I could not find a single cylinder anywhere. I am going to have to heavily modify the pedal to get it to work.
Old 02-22-08, 11:15 AM
  #64
twojayzee
twojayzee's Avatar
You'll have to take pix when you get it. I was looking at the diagram and it looks like you could just make the ballance bar fixed so it doesnt pivot like this
Old 02-22-08, 11:25 AM
  #65
SuprRunner
SuprRunner's Avatar
Nope, that won't change anything. I will have to take a picture of the assembly.
There is a 1" bore at the top of the pedal that a thread rod goes through. The rod is only about 3/8" in diamter, with a master cyl linkage on each side which are also threaded onto the rod. There is a pivot in the center of the bore that the rod goes through. The only thing you can adjust is how far each master cyl linkages is from the center of the pedal, adjusting the leverage to each cylinder. If there is nothing to push on the opposite side of the bar, then there is no leverage at all. I could make a steel bushing to put into the bore the rod cannot pivot. This way I can modify it without cutting/welding.
I hope that makes sense.
Old 02-22-08, 11:28 AM
  #66
SuprRunner
SuprRunner's Avatar
Old 02-22-08, 11:44 AM
  #67
twojayzee
twojayzee's Avatar
Thats exactly how I meant it to come out.
Old 03-09-08, 03:49 AM
  #68
yesca
yesca's Avatar
A short video that a friend shot and put up for me, hope you enjoy
http://www.youtube.com/watch?v=HFutXMv7iDk
Old 03-10-08, 07:19 AM
  #69
Lexatlast
Lexatlast's Avatar
very nice... do you normally drift with those rims?
they look more like show rims than drifters...
regardless! very nice!
Old 03-10-08, 08:49 AM
  #70
SuprRunner
SuprRunner's Avatar
Very nice. I will have to say that his girly screaming was getting VERY annoying though.
Old 03-10-08, 09:01 AM
  #71
Lexatlast
Lexatlast's Avatar
hahaha and thats the truth...
Old 04-21-08, 01:12 PM
  #72
yesca
yesca's Avatar
I finally got around to putting these on. Changing the rear parking brake shoe was a pain in the butt!!!
Old 04-21-08, 02:47 PM
  #73
zazzn
zazzn's Avatar
any kinda write up / tips of what needed to be modified for the 5 spd.
I have a spare r154 on the floor. An Aristo... and the itch for 5 spd.
I don't like the idea of drilling a whole for the clutch peddle though
Old 04-21-08, 03:10 PM
  #74
SuprRunner
SuprRunner's Avatar
why is that such a bad thing. Almost all cars have a hole. Besides the master cyl has a rubber boot on it.
And on a side note, unless you get a soarer R154, you will have to lengthen the shifter housing like this:
Old 04-22-08, 09:31 AM
  #75
chewy
chewy's Avatar
man looks like it comin right along! sweet *** ride dude
Quick Reply: 5 speed Aristo Swap Almost Done
