need help..engine won't start up
Old Jul 31, 2007 | 06:35 PM
atl4love's Avatar
atl4love
Default need help..engine won't start up
i need some help with my car,yesterday my brother took my car to local shop to change the battery and he hook up the new battery but he was put the wrong negative and possitive input,the main fuse is blow ,put the new one in and i was double check for all fuse but the engine won't start up,it was crank ,all i smell is gas ..please help me out...thank a lot..
Old Aug 1, 2007 | 07:45 AM
95gs300's Avatar
95gs300
I have the same problem with my other car if find something let me know and I'll do the same.
Old Aug 1, 2007 | 07:49 AM
Kaiser's Avatar
Kaiser
Switch ECU's and see if it starts.^^^^^^
Old Aug 1, 2007 | 07:55 AM
95gs300's Avatar
95gs300
Damn that sucks I was planning on selling the car lol its a 98 mits mirage.... But thanks for the help.
Old Aug 1, 2007 | 10:05 AM
Aristo-cat's Avatar
Aristo-cat
start simple, you need spark and fuel to start a car. You smell fuel, but make sure its priming, pull the fuel line hose and put a bottle on the end. turn the key to the on position and if fuel squirts out... thats good! If you have that, you need spark. check all fuses related to ignition. check grounds. Start there.
Old Aug 1, 2007 | 06:05 PM
atl4love's Avatar
atl4love
since my car was gte swap. i don't know what else to check , all i can tell is fuel is fine but no spark, i dont know if there is any hidden fuse anywhere inside the car..let me know if you have any idea..thank
Old Aug 3, 2007 | 01:40 AM
resen323's Avatar
resen323
check your EFI fuse
Old Aug 4, 2007 | 07:55 PM
atl4love's Avatar
atl4love
the EFI Fuse is fine..what else to check????
Old Aug 4, 2007 | 09:38 PM
SeanB's Avatar
SeanB
I accidentally dropped a wrench on something under the hood and fried the ecu of my old 91 Saab 9000 turbo. Check the ecu bro.
Old Aug 4, 2007 | 11:38 PM
ethan_phan's Avatar
ethan_phan
i think so...i will buy another ecu...if it is not solve the problem i'm in deep shiet...thank for your help...
Old Aug 7, 2007 | 08:47 AM
SeanB's Avatar
SeanB
Before you buy one see if you can GET A FRIENDS ECU OR ASK THE SHOP OR SALVAGE YARD TO LOAN IF THEY'LL LET YOU AND DO A SWAP. Don't be so fast to buy another one just yet. That's what I had to do before coming to that conclusion.
Old Aug 8, 2007 | 06:27 PM
atl4love's Avatar
atl4love
got another aristo ecu from a member today,but the car won't start either,now i'm in deep shiet...don't know what else to check..my stupid brother jezz...
Old Aug 8, 2007 | 06:50 PM
plkyone's Avatar
plkyone
Well i think you said that you have fuel but no spark.
Does everything else in the car power up?
make sure to check all the relays under the hood
fuse box under driver kick panel also relays to the left of the parking brake towards the firewall
Use a Noid light to check you injectors (the injectors might be just dumping fuel insted of pulsing)
also use a meter and check the pulse to the coil pack's
Old Aug 8, 2007 | 07:52 PM
atl4love's Avatar
atl4love
everything power up as normal, only the engine can't start up,thank for your help..i will check for the relay ,,but i don't know how to check for the relay if it is goin bad...what the best way to check for the relay??? let me know if you have an idea..thank you
Old Aug 8, 2007 | 08:04 PM
Kaiser's Avatar
Kaiser
Do you have an AFC or something?
