HELP!Wheel alignment or steering column problem??
Old Oct 12, 2006 | 07:12 AM
BrooklnLex's Avatar
BrooklnLex
Unhappy HELP!Wheel alignment or steering column problem??
Hey 1st gens!
I had a wheel alignment done in August. I had to go back recently to have it adjusted, however it's still veering off to the side, especially on uneven pavement or pavement that is 'too smooth". I keep experiencing a "bump steer". I have to keep pulling the steering wheel in order to straighten it up. While turning, I have to do extra work to straighten up and to get the signal to turn off after the turn has been completed. Could there possibly be a problem with the steering column and not the alignment? If so, is this costly to fix?
Also, the third break light (top center) is out; what type of bulbs are used for this, can any retail auto shop fix it?
Thanks,
BrooklnLex
1994 GS 300 172+K
Old Oct 12, 2006 | 04:51 PM
Xeeeeeem's Avatar
Xeeeeeem
I'm having the same issue. I know my rack and pinion is goin out...leaking, but i'm not sure if thats the problem.
I believe its the brakes. Although i had 4 new calipers pads and discs installed last year, i think my left rear is sticking again. The disc is super shiny and i think it coaled up and cooled down. Since its the left rear, my car is pulled to the left and its a big PITA. Oh well.
3rd Rear taillight is LEDs and there no way all 50,000 of them burned out at once, i'm not sure if its a fuse or a bad wire somewhere...just guessing.
Najeeh
Sep 30, 2015 11:11 AM
spitfire7
Apr 1, 2012 10:47 PM
feejap
Jun 29, 2010 02:50 AM
almost_g
Nov 16, 2007 07:26 AM
03LX470
Feb 2, 2003 02:59 PM
