Engine Bay Firewall
Old Apr 13, 2005 | 07:50 AM
hollafront's Avatar
hollafront
Default Engine Bay Firewall
i am installing nos into my 1994 gs and i need help in finding the firewall so i can run my lines through my car...can someone please provide me with pictures or instructions as to where i might be able to find the firewall....
much appreciated
Old Apr 13, 2005 | 08:44 AM
CTgs300's Avatar
CTgs300
The firewall??? That is the metal that seperates the engine compartment from the passenger compartment. If you are having trouble locating this DO NOT install N.O.S. YOURSELF!
Old Apr 13, 2005 | 08:47 AM
hollafront's Avatar
hollafront
ok...is there any way i can run my lines through the inside of my car?
Old Apr 13, 2005 | 09:15 AM
CTgs300's Avatar
CTgs300
are you mounting the bottle in the trunk? You are going to have to drill some metal either way you look at it so I would look for places that aren't going to be affected by water etc. You will definetly need some rubber grommets to prevent fraying of wires hoses through the shhet metal. If someone else has done this I wonder if they ran everything through a stock location? so you won't have to hack away at the car....
Old Apr 13, 2005 | 09:19 AM
TLW's Avatar
TLW
please becareful
have you ever run lines for before
i think this is something you want a pro do to or at least consult one
Old Apr 13, 2005 | 09:30 AM
SlowGS3's Avatar
SlowGS3
I had a performance shop installed a wet kit for my previous car and they ran the NOS line under the car to the trunk.
Old Apr 13, 2005 | 11:45 AM
turbogs300's Avatar
turbogs300
Cool
Yep, Run it under the car(away from any sources of heat). Let the pros do it!
Old Apr 13, 2005 | 12:33 PM
lexus4jess's Avatar
lexus4jess
much appreciated
CTgs300 = The firewall??? That is the metal that seperates the engine compartment from the passenger compartment. If you are having trouble locating this DO NOT install N.O.S. YOURSELF!
Dunno where the firewall is,you should let the pros do it.Are you being funny????
Old Apr 15, 2005 | 12:28 PM
hollafront's Avatar
hollafront
aLrite thanks guys....Pros fo sho then
Old Apr 20, 2005 | 10:52 PM
hollafront's Avatar
hollafront
hey...one more question.......where can i safetly drill a hole so i can run the lines through my car to the trunk...
Luxor
Apr 29, 2022 07:38 AM
deputy865
Dec 29, 2014 04:27 PM
vindedreal
Apr 5, 2009 10:35 PM
menty
Feb 3, 2009 03:55 PM
