I'll find out tomorrow. I'll be trying the top end engine cleaner in the morning, a little bit at a time.
1/3 in the crankcase and 1/3 in through a vacuum line.
You should clean all the buildup around the throttle plate with carb cleaner as well, usually there'a alot if it hasn't been done. It will definitely help.
Will do. Hopefully I can avoid a head rebuild and clean out the lifter.
