HELP! alternator problem
Old Nov 3, 2004 | 11:16 PM
ZeekGS300's Avatar
ZeekGS300
Default HELP! alternator problem
i need help.
i cant even have a system without my car ready to die out. my battery will die and i would need a jump start. what would you think it is? my alternator? if so its going dead or i need a bigger alternator? anybody gots a big system in there gs3 that replaced there alternator with a bigger alternator? my dash will dim out and my in dash will start to dim out then restart . so where can i get a bigger alternator at?
Old Nov 3, 2004 | 11:53 PM
Jmai22's Avatar
Jmai22
probly just a worn out stock alternator. I use to run 1400watts rms on my system and the dash barely dimmed here were my specs
JBL 1000.1 for my subs Alpine Type R wired down to 2 ohms
Rockford F. 400.4 to run my mids and highs.(Mb quarts)
It was a low-mid end system that sounded clean but i rarely had dimming or starting problems. Just get your alternator rewound for the most cost effective solution, and if it continues to dim upgrade to a yellow top battery by optima which i later on did because i played my sound system for hours at a time with the engine off.
Old Nov 4, 2004 | 03:55 PM
ZeekGS300's Avatar
ZeekGS300
i might go on head and do that. they cost $$ for a new alternator hehe.
rakett
Aug 21, 2014 04:05 AM
HiPSI
Apr 8, 2011 04:11 PM
lakemist
GX - 1st Gen (2003-2009)
Aug 5, 2009 11:11 PM
ArmyofOne
Maintenance
Nov 22, 2008 03:15 PM
Neo
Maintenance
Nov 30, 2004 06:29 PM
