EV Chat General discussion about electrified Lexus, other EV vehicle manufacturers and BEV, PHEV related industry news.
Kia EV6
Old 03-15-21, 11:27 AM
Hoovey689
Hoovey689's Avatar
Default Kia EV6
The Kia EV6 electric car has finally been revealed. It's the first Kia to use the E-GMP platform, like the Hyundai Ioniq 5. It looks dramatically different from that car, though we have yet to know if the specifications will differ much.
While the Ioniq 5 has a relatively conventional and very angular hatchback shape, the Kia EV6 has a curvy, coupe-like shape. The nose is wide and blunt with a grille and headlights that wrap around the leading edge with a slight scowl. The roofline is low, as is the hatchback, with a window sill that rises rapidly into a thick rear pillar for aggressive coupe profile. The rear has unique, thin taillights that span edge to edge, and the angles of them match the angles of the side sills.
The inside looks like a more streamlined and minimized version of the Kia K5's interior. The instrument panel and infotainment screen are fitted in one wide monolith on top of the dash. That dash is low and simple with full-width air vents. The car also has a floating center console that looks like it probably slides like the one in its Hyundai sibling.
Unfortunately, Kia hasn't said anything about motors, power and battery capacity. We're expecting it to match the specs of the Ioniq 5 with single-motor, rear-drive and dual-motor, all-wheel-drive versions making either 215 horsepower or 302. It will probably be offered with a base 58-kWh battery and a long-range 77.4-kWh battery. We also don't have an on-sale date, but that will probably be sometime this year.
Source
Old 03-15-21, 11:28 AM
Nice looking KIA.
Old 03-15-21, 03:23 PM
mmarshall's Avatar
Front end looks good. Inside, I see it uses the same two-spoke steering wheel as the Genesis G80, although with different texture and logo. I could do without that rotary-shifter, though.
Old 03-15-21, 03:28 PM
Hoovey689
Hoovey689's Avatar
They look pretty different
Old 03-15-21, 03:29 PM
JDR76
JDR76's Avatar
Received 1,610 Likes on 1,026 Posts
I like this!
Old 03-15-21, 05:27 PM
GFerg
Speaks French in Russian
GFerg's Avatar
I prefer the retro look of the Ioniq 5, but this looks outstanding too. Kia/Hyundai/Genesis have been pumping out A LOT of new product recently. Very cool to see.
Old 03-15-21, 05:32 PM
EZZ
EZZ's Avatar
I hope they give it a stronger powertrain. Its proven that their 800V architecture charges super fast. A little tweak to their motors to take advantage of the architecture could probably have the car smoke the Stinger. Maybe EV6 N Model?
Old 03-16-21, 11:36 AM
Hameed
EV ftw!!!
Hameed's Avatar
I think it looks very promising!
Old 03-16-21, 01:16 PM
Fandi
Fandi's Avatar
Face looks quite similar with VW ID.4 but nicer. Probably because of the lines between the headlight
Old 03-16-21, 01:20 PM
mmarshall's Avatar
To an extent maybe, but it still looks like it came from the same basic design.
Old 03-17-21, 12:16 AM
Fizzboy7
Fizzboy7's Avatar
Pretty safe to say this will not be powered by any form of a V6... so why call it an EV6? Just playing with people's minds at that point.
Front is a carbon copy of the ID4. Could have led the path with something different there- lazy effort. Rest of the body looks great.
I think the core future for most brands will be cars just like this.
Old 03-17-21, 05:18 AM
Blaze876
Blaze876's Avatar
because it's an EV? And 6 is part of the model number? seems like a non issue.
Old 03-17-21, 08:57 AM
Motorola
Motorola's Avatar
The proportions and silhouette definitely remind me of the Jaguar I-Pace. It's interesting how different it is from the Ioniq 5, which it shares a platform with.
Old 03-30-21, 08:22 AM
Hoovey689
Hoovey689's Avatar
Default Kia EV6 GT will do 0-60 in 3.5 seconds
The parade of new electric vehicles continues with the 2022 Kia EV6, a crossover-ish vehicle with surprisingly aggressive performance numbers. Although we have previously seen the EV6, today we get new pictures and key specs, including a maximum range of 316 miles on the WLTP combined cycle (EPA range would be less), a minimum 0-60 time of 3.5 seconds in the EV6 GT model, and a recharge from 10% to 80% in just 18 minutes thanks to the 800-volt charging capability on every version.
The EV6 uses the same Electric-Global Modular Platform (E-GMP) as the Hyundai Ioniq 5, and roughly shares its available battery capacities. However, as is often the case with Hyundai and Kia vehicles that share a common platform, they clearly split early in the development process, as their dimensions, specs and designs show little sign of common DNA
The EV6 wheelbase of 114.2 inches isn't as unusually lengthy as the Ioniq 5's (118.1), but is still considerably longer than the VW ID.4 and Nissan Ariya. Its overall length is greater than all of the above, however, at 184.3 inches (or 184.9 for the EV6 GT), a figure that puts it closer to the 186-inch Mustang Mach-E. At 61.0 inches tall, it is 2 inches shorter than both the Ioniq 5 and Mach-E, which themselves are pretty low for vehicles considered crossovers. In other words, like so many electric vehicles, the EV6 has unusual dimensions resulting from engineers and designers taking advantage of the inherent differences between a dedicated EV platform and an internal combustion one.
Like the Mustang Mach-E, the EV6 offers a diverse menu (some would say complex) of performance and range that's dictated by battery size, driven wheels and trim level.
The EV6 and EV6 GT-line (pictured in red above) offer a choice. Things start with a 58 kilowatt-hour Standard Range battery pack. When paired with a rear motor only, it results in a rather modest 168 horsepower and 258 pound-feet of torque. Adding a second motor for all-wheel drive pumps things up considerably to 232 hp and 446 lb-ft. Kia did not indicate range estimates for this battery pack.
The available 77.4-kWh Long Range battery pack kicks output up to 232 hp and 258 lb-ft with the rear motor only. It is this version that results in the best possible range, an estimated 510 kilometers or 316 miles on the WLTP cycle, which should likely put the EPA range in the mid-to-upper 200-mile range. The second motor/AWD yields 321 hp and 446 lb-ft, but no range estimate was given.
The EV6 GT comes only with the pairing of Long Range battery and more powerful motors on both axles that results in 577 hp and 546 lb-ft of torque (it also gets an electronic limited-slip differential). This is the version that Kia says will go 0-to-60 mph in 3.5 seconds. No Ioniq 5 comes remotely close to this performance, and you'd have to look to higher-end Teslas and the upcoming, top-of-the-line Mustang Mach-E GT Performance to get that sort of neck-snapping acceleration from an EV or any number of high-end ICE sports cars. We were not expecting that.
All versions support 400-volt and 800-volt charging, with the latter enabling an ultra-fast 10-80% recharge in 18 minutes. It can also regain 62 miles of range (again, WLTP) in 4.5 minutes. This capability is shared with the Ioniq 5 and is a key attribute of Hyundai's E-GMP platform. Another atypical benefit is the EV6's Integrated Charging Control Unit (ICCU), which includes a "vehicle-to-load" function that basically turns the car into a generator. Kia says it can supply as much as 3.6kW of power that can operate a 55-inch TV and an air conditioner simultaneously for more than 24 hours. It can even charge another electric car. Nifty.
As with most other EVs not produced by Audi or Porsche, the EV6 allows for one-pedal driving. However, it stands out by offering six regenerative braking levels: none, 1 to 3, auto mode and "i-Pedal," which is the maximum mode that can bring the car to a stop without the driver touching a pedal.
Now, having touched on the electric vehicle requisites of maximum range and 0-60 times, let's move inside to discuss the other must: a big touchscreen. The EV6 has a pair of curved 12-inch screens – one for the instrument panel and the other touch-operated for the infotainment system. The latter is angled toward the driver, which is always appreciated. Judging by the photos, this appears to feature a new UI for Kia. We hope it'll remain just as user friendly as what's available now.
Admittedly, the EV6 screen isn't as eye-popping as Tesla's or the Mustang Mach-E's, but its curved display is pretty cool and the available head-up display features augmented reality capability like the new Mercedes S-Class. The HVAC controls are also a separate touch-operated panel, which is configurable. Over-the-air updates are possible.
The uni-spoke steering wheel looks vaguely similar to what you'd find in the EV6's corporate cousins, the Genesis G80 and GV80. Speaking of those, the EV6 is the only other Hyundai Group vehicle besides them to offer the next-generation Highway Driving Assist II that builds upon the advanced adaptive cruise control and lane-keeping system available on the Kia Telluride and other Hyundai Group Vehicles with a machine-learning capability that allows for automated lane changes and adjusts its behavior to the driver's style.
Basically, Kia has thrown every tech feature at its disposal at the EV6, while also providing clear differentiation between both its Hyundai Ioniq 5 cousin and various other electric cars. Pricing was not announced, but considering the differences in available performance, we would expect the price range to be similarly vast. The EV6 will be produced in Korea and will go on sale in the second half of 2021 with online reservations starting today (March 30). It also expects to sell 20,000 in the United States.
"EV6 is the embodiment of the new Kia," said Kia President and CEO Ho Sung Song in a press release. "(It) represents the beginning of Kia's long-term commitment to sustainable mobility, accelerating the transition not only to clean transportation, but also products, materials and manufacturing."
The company says it will produce 11 new electric models by 2026, with seven built on the E-GMP platform and four based on existing models. It also says that 40% of Kias will be electrified (EV, plug-in hybrid and regular hybrid) by 2030.
Source
Old 03-30-21, 08:28 AM
sdls
sdls's Avatar
0-60 in 3.5s is very very very very very fast. Some impressive specifications for Kia.
That makes me wonder about Kia’s place with regards to Hyundai. How are the brands being differentiated now? What is Hyundai’s vision for the brand and how do they want to direct the flow of buyers to one brand vs the other?
Quick Reply: Kia EV6
