Help Please 🙏 2019 ES350 engine problem
Subscribe
Sep 10, 2020 | 04:57 AM
Hope all Lexus owners and their loved one safe.
really I need your help guys,
my issue started one day after driving around 30 miles on highway, then after 4 hours I started the engine, the engine started vibrating like "low fuel coming to the engine or something else" and I can tell notice coming from Engine Intake Manifold! I turned off the car then i turned on, the engine it better then before but the vibration still there. the engine is not smooth and i can feel the vibration on steering wheel. the car still new just 15k miles on it , and from that happened until now I drove around 2000 miles and can't figure what the issue. no warning lights or messages. I bought the car from America and shipped it overseas, and the stupid limited dealership over here doesn't accept any overseas cars.
You can hear the noise that coming from the Engine Intake Manifold 👂👂👂
Reply 0
Sep 10, 2020 | 08:58 AM
Doesn't sound like a healthy engine. Did you check the oil level?
Reply 0
Sep 10, 2020 | 09:04 AM
Quote: Doesn't sound like a healthy engine. Did you check the oil level?
I changed the Oil with all filters and also i put new tires and nothing change
Reply 0
Sep 10, 2020 | 09:35 AM
If the car was dangerously low on oil the damage may already been done. I am not saying this is the case and hope it isn't as it would be very expensive to fix. You are going to have to find a mechanic. Good luck.
Just curious, how much did you saved from buying it in U.S and have it shipped over to South Africa versus buying one over there at local dealer?
Reply 0
Sep 10, 2020 | 10:05 AM
Sounds like an emissions issue to me... I would try to see which, if any, codes are displayed through the OBD2 adapter.
Reply 0
Sep 10, 2020 | 10:36 AM
Quote: If the car was dangerously low on oil the damage may already been done. I am not saying this is the case and hope it isn't as it would be very expensive to fix. You are going to have to find a mechanic. Good luck.
Never had issue with oil and i change the oil every 5000 miles. about the price almost half what cost in here.
Reply 0
Sep 10, 2020 | 10:41 AM
Quote: Sounds like an emissions issue to me... I would try to see which, if any, codes are displayed through the OBD2 adapter.
No any Emissions coming from the exhaust, also, no warning lights or messages even i checked with OBD2 and got nothing.
Reply 0
Sep 10, 2020 | 11:04 AM
What kind of noise is it from the intake? Any leaks? With only 15k on the clock would be unlikely to be the intake manifold gasket leaking. You require a diagnostic evaluation my friend.
I would be interested in knowing what you find to be the issue.
After more thinking, could be a bad load of gasoline. Did it run well before this?
GOOD LUCK!
Reply 1
Sep 10, 2020 | 06:48 PM
Keep us posted as I am curious about the root cause as this seems highly unusual for a car such low miles. For the few first seconds of the video I thought I was looking at a very old engine. I guess you're living in a very dusty environment.
Reply 0
Sep 11, 2020 | 02:17 AM
Try changing the spark plugs and add a fuel injector cleaner to the fuel tank.
And try to use higher octane fuel.
Reply 0
Sep 11, 2020 | 04:59 AM
Quote: What kind of noise is it from the intake? Any leaks? With only 15k on the clock would be unlikely to be the intake manifold gasket leaking. You require a diagnostic evaluation my friend.
GOOD LUCK!
kicking other than the normal noise coming from that area with that vibration. there is no leaks at all. yes I know the issue no trusted shop in here except the dealership
I will keep you posted brother
Reply 0
Sep 11, 2020 | 05:19 AM
Quote: Keep us posted as I am curious about the root cause as this seems highly unusual for a car such low miles. For the few first seconds of the video I thought I was looking at a very old engine. I guess you're living in a very dusty environment.
Will do ionian2k 👍 what make me sad that i bought the car and was on it 8K, and now 15K I only drove the car for 7K. That dust it normal here I live in the Middle East.
Reply 0
Sep 11, 2020 | 05:27 AM
Quote: Try changing the spark plugs and add a fuel injector cleaner to the fuel tank.
Do you think with this mileage it needs to be done? and yes since I bought the car I only use 95 RON octane. Do you think that fuel pump can cause that?
Reply 0
Sep 11, 2020 | 05:43 AM
Quote: Do you think with this mileage it needs to be done? and yes since I bought the car I only use 95 RON octane. Do you think that fuel pump can cause that?
It is good to use 95 RON in the Middle East and the GCC. And Lexus recommends using Lexus Fuel Injector Cleaner every 10000KM. Before removing all the spark plugs try to remove one or two to see in which shape they are. and regarding the fuel pump failure recall, it might cause this issue because once the fuel pump fails it won't pump enough fuel to the engine and causes vibration.
Reply 0
Sep 11, 2020 | 06:04 AM
Quote: It is good to use 95 RON in the Middle East and the GCC. And Lexus recommends using Lexus Fuel Injector Cleaner every 10000KM. Before removing all the spark plugs try to remove one or two to see in which shape they are. and regarding the fuel pump failure recall, it might cause this issue because once the fuel pump fails it won't pump enough fuel to the engine and causes vibration.
I will try and do that, but the big issue the fuel pump, the car out of the states and i can't fix it under warranty it cost around $1000 without label work
Reply 0
