ES - 7th to 8th Gen (2019-present) Discussion topics related to 2019-present ES models
Wheels doesn’t spin without any code 😟
Old Jan 8, 2024 | 01:16 AM
lee353535's Avatar
lee353535
5th Gear
Default Wheels doesn’t spin without any code 😟
I'm having a serious problem that I can't solve with my 2019 Lexus es, the fact is that after I drove for 10 hours to visit my aunt in a small city, now when I turn on the phone, everything is normal, but when I put the number to D or R and press the gas, the car doesn't move and the wheels don't turn. 3 hours from my aunt's house from Lexus. And I'm doing everything I can to help the car move again. So I really need everyone's opinion to help
Old Jan 8, 2024 | 01:26 AM
lee353535's Avatar
lee353535
5th Gear
Video of my car
File Type: mov
Old Jan 8, 2024 | 08:28 AM
GabC's Avatar
GabC
sorry to hear about your car.
you'll need to pull the diagnostic codes to see what the issue is. you can purchase it from almost any auto shops like autozone, Advance Auto, O'Reilly, Napa, and etc. Or take it to a trusted auto garage and have them take a look at it.
What i think it could be is a broken front axle or it popped out of the transmission case. Get it to a shop and lift it up to get a better look at whats going on.
Old Jan 8, 2024 | 01:04 PM
lee353535's Avatar
lee353535
5th Gear
thank a lot for your reply, and I just use OBD2 scan by fix and app show no code . No engine light, only matter waning light (!) on my dash Screen. Do you thing happen with senso, fush, system “ TCM , ECM “ 🤒
Old Jan 8, 2024 | 02:30 PM
grp52's Avatar
grp52
On your second video, the Multi Information Display (MID) is showing "Headlight System Malfunction Visit Your Dealer" (at 2 seconds) and "Pre-Collision System Malfunction Visit Your Dealer" (at 5 seconds) messages (at least some of the reason the Master Warning light is on) so you should get some DTC codes with your OBD2 scanner. (The MID is also showing the hood and trunk open graphic but I don't think either of those will cause the "Headlight System Malfunction Visit Your Dealer" message.)
Old Jan 8, 2024 | 02:39 PM
lee353535's Avatar
lee353535
5th Gear
Because I just replaced the new bumper last month, some of the front sensors are not working, but I will check again later, maybe because I use the car too much, so the transmission system has a problem, I must pull the car to the dealer for them to check. Thank again for your help 🤝
Old Jan 9, 2024 | 04:42 AM
toyotaman7's Avatar
toyotaman7
Is the shifter cable connected to the transmission?
BTW, You should never rev the engine this much when shifting. That would damage it.
Old Jan 9, 2024 | 07:50 AM
lee353535's Avatar
lee353535
5th Gear
thank for your tip 🤝 and Can you explain more where shifter cable switch wire is located
DJWLDW
Oct 17, 2022 06:02 AM
Grazy
IS - 1st Gen (2001-2005)
Dec 3, 2009 12:13 PM
Gojirra99
Mar 19, 2006 04:35 PM
