Aftermarket Battery
Old Jun 21, 2023 | 02:18 AM
Gawein's Avatar
Gawein
Default Aftermarket Battery
I've had enough with the OE battery in my 2022 ES 350 that keeps dying on me. What are some of the best aftermarket brands for batteries that we can fit?
Does DCM always use our battery and slowly drain it and is it worth disabling? Has anyone upgraded to Optima? Looking for as many options and recommendations as possible.
Old Jun 21, 2023 | 04:02 AM
ESh's Avatar
ESh
Did you visit the dealer? They will test it and replace it
Old Jun 21, 2023 | 04:11 AM
93SCMax's Avatar
93SCMax
I assume with a 2002 in the USA, you are still under warranty. I'd bring it into the dealer as suggested by ESh. You may have a charging problem that a new battery won't correct.
Old Jun 21, 2023 | 04:55 AM
bc6152's Avatar
bc6152
First, a trip to the dealer for a free battery. Otherwise in previous posts most members go to Costco for an Interstate.
Old Jun 21, 2023 | 06:15 AM
mikemu30's Avatar
mikemu30
My battery is going on five years old - never had an issue but I'm about to replace it just cause it's about time.
Old Jun 21, 2023 | 09:23 AM
Gawein's Avatar
Gawein
Well, here’s the thing. I run a dash cam and often use parking mode, it has drain protection. I should have another dedicated battery for it, but I’d rather not go that route. OE battery is just not up to task, hence I’m looking for a more robust deep cycle aftermarket. A dealer installed new battery will probably be another quick let down.
Old Jun 21, 2023 | 09:28 AM
E46CT's Avatar
E46CT
Ah that explains it. Cameras do cost some energy - trust me i know! My Tesla is running total of 9 (nine) cameras 24/7 full recording. It does cost an extra 1% per day, but no biggy since i am charging. I do have the option if disabling it at certain GPS locations if i want.
Old Jun 21, 2023 | 11:24 AM
Gawein's Avatar
Gawein
Do you run a dash cam setup on top of the sentry mode? I would think unnecessary. Man, those tesla cams are awesome even though they still have some blindspots.
Old Jun 21, 2023 | 11:40 AM
minotaar's Avatar
minotaar
This is really interesting. I didn't know you could do that with another battery. Are you saying you'd have a second battery connected to the alternator that would only power the dashcam in parking mode? Or just another battery that you'd charge independently of the car altogether.
Old Jun 21, 2023 | 11:47 AM
shoodes's Avatar
shoodes
While I don't own a 7ES, this is a strange issue.
I have a VIOFO A129 Plus Duo hard-wired in my 6ES and I don't have any issues with the battery draining. The hardwire kit I used also has a voltage cut-off you can set (11.8V - 12.4V) where it will automatically shut off if it detects the car battery voltage as too low.
I do drive it every day though, so if you had it hardwired and were leaving it off for longer than a week, I could see that being an issue. I do have an Interstate Battery from Costco though, not the OEM one.
Is your hardwire kit a 3 wire? It should auto shut off if it detects the voltage being too low from the car battery preventing this from happening.
Old Jun 21, 2023 | 11:50 AM
shoodes's Avatar
shoodes
I think OP is talking about this, https://www.blackboxmycar.com/collections/battery-packs.
It's like a hardwired pack that you wire to the camera instead of having it go directly into a fuse/always on power source. They usually charge while you drive and then it powers your dashcam while you are parked and the vehicle is off. Some people do this over hard-wiring their dashcam to an always on power source.
Old Jun 21, 2023 | 12:03 PM
E46CT's Avatar
E46CT
No supplement dash cams. Tesla is in the process of rolling out OTA updates to have full access to all 9 cameras where was previously 3 of the 9 cameras were restricted. So there really shouldn't be any blind spots now for Sentry purposes. But even before, you had front, left, right, and rear. So unless you mean the sky, not sure what Sentry blind spots you mean?
Old Jun 21, 2023 | 12:09 PM
Gawein's Avatar
Gawein
Yes, I have the voltage cut off, I also test my music a lot without engine running... I know this is the main culprit haha. All in all, OE battery is too weak to handle extended parking mode recording anyways.
Old Jun 21, 2023 | 12:11 PM
Gawein's Avatar
Gawein
oh wow! I surely thought it still had some blind spots. I guess no longer
Old Jun 21, 2023 | 12:12 PM
Gawein's Avatar
Gawein
I definitely meant an additional battery pack designed for dash cams that you would place inside the car, typically under the seat.
