Yellow line
Old Apr 21, 2025 | 04:19 PM
  #31
mmatheny's Avatar
mmatheny
Originally Posted by Brianses7
I figured out how to properly do this for the 2021 ES350 and it was a bit difficult. They say it's the same as Camry and RAV4 however they forget those cars don't have the same screen as the ES and the touch pad.
So, make sure you have the car on and steering wheel straight. Hold the menu button next to the touch pad and flick your lights on and off 3 times. This will make the infotainment screen go into a service mode.
Now you're going to see many options like, Failure diagnosis, Functions/Check settings, Service information, and product information.
Using the touchpad select functions/check settings, then camera settings, now hold down and press steering angle setting then press next. You should now see 2 options steering center memorize and max steering angle memorize.
Select steering angle memorize and then turn your steering wheel all the way to the left and hold it there. Then press max steering angle memorize, turn the wheel all the way to the right and press max steering angle memorize again and you will hear a beep.
Turn the car off then turn it on and exit the service mode. Put your car in reverse and see the lines! If anyone wants some pictures of what these screens look like I'd be happy to post some this weekend.
This worked a charm - only caveat is you need to press the Return button to move from button to button!
Is there a manual of all the service mode settings & what they do? I have a 2021. Thanx
Old Apr 22, 2025 | 05:26 AM
  #32
mikemu30's Avatar
mikemu30
Don't feel bad Mike - it took me about ten tries more than a year ago to get it to work!
Old Apr 22, 2025 | 12:41 PM
  #33
Tootsall's Avatar
Tootsall
Darn...can't get it to work on '20 with Nav. Parked outdoors. Ignition ON (engine running or not...neither worked). Auto dim turned OFF. Hold Menu and flip switch between Park and On (away from "Auto"). Three flips, four, six....nada. Must be something simple I'm missing but what Does there have to be an error message first? I was curious as to what the menus offered.
Edit: OK, got it. Possibly unique to Canadian versions due to difference in operation of daylight driving lights. Start with light switch in OFF position. Hold the MENU button and flip the light switch between OFF and AUTO 4 times. That'll bring up the service menu (at least on the NAV screen). This worked inside the garage with ignition ON but engine not started.
Googs
RX - 4th Gen (2016-2022)
May 17, 2018 09:09 PM
hoplim
Apr 30, 2017 08:18 PM
gman1227
Jul 12, 2008 09:35 AM
JIMMY540i.com
Aug 25, 2007 02:03 PM
SandRock
13
Jun 6, 2002 02:02 AM
