Yellow line
So I found this post in another thread and hope this will resolve my lingering NO YELLOW LINES issues.
Quote:
Originally Posted by Oldfart
There is a way to reset rear camera detection. There was discussion about it recently.
Winner winner chicken dinner! The YT video you suggested did not work, but looking at several videos I got er done. For those that care, on the 2019 ES350 you have to go into the service menu: With the car running you hold the menu button by the touch pad and turn the lights on and off 3 times. Then you chose the Function setting, then the camera setting. You arrow down with the back or return button next to the menu button. You choose the greyed out setting button and hold your finger on the touch pad for 3 seconds. That takes you to the menu where you can memorize the steering wheel center and angle settings. Center the steering wheel and select the center setting. Now you turn the wheel all the way to the left, then all the way to the right. Center the wheel and select the Angle button. Turn the car off and then restart it and all is good!
-MarcLast edited by Plummit; 01-20-23 at 11:00 PM.
Can't thank you enough! Just bought a used 2019 ES 350 which had been completely reset and had no yellow guidence lines. Was told I had to take it back to the dealer which is over an hour away, until I found this. Worked perfectly. Thank you VERY much!
I just went thru this about a week ago when my battery went south. Found this video on YOUTUBE and it worked perfectly for me. All functions restored by using the instructions. Some other members tried it and couldn't get it to work but it did for me...
https://www.youtube.com/watch?v=r1YzgSlRBLM
Bob C.
I figured out how to properly do this for the 2021 ES350 and it was a bit difficult. They say it's the same as Camry and RAV4 however they forget those cars don't have the same screen as the ES and the touch pad.
So, make sure you have the car on and steering wheel straight. Hold the menu button next to the touch pad and flick your lights on and off 3 times. This will make the infotainment screen go into a service mode.
Now you're going to see many options like, Failure diagnosis, Functions/Check settings, Service information, and product information.
Using the touchpad select functions/check settings, then camera settings, now hold down and press steering angle setting then press next. You should now see 2 options steering center memorize and max steering angle memorize.
Select steering angle memorize and then turn your steering wheel all the way to the left and hold it there. Then press max steering angle memorize, turn the wheel all the way to the right and press max steering angle memorize again and you will hear a beep.
Turn the car off then turn it on and exit the service mode. Put your car in reverse and see the lines! If anyone wants some pictures of what these screens look like I'd be happy to post some this weekend.
I tried the menu + flicking the light switch, it didn't work.
Does this work on 12.3inc touchscreen + touchpad model? Mine is 2021.
Edit: It worked. You need to make sure your auto light is not on. Don't do it in the garage or put your phone's flash light on the headlight sensor...
