Musty smell after it rains
Old Nov 26, 2021 | 08:40 PM
irobot2090's Avatar
irobot2090
Default Musty smell after it rains
I am not sure where is it, already checked for leak inside and found nothing. Smell like molding after the rains and even after a week of sunny, sometime I still smell it inside the car. Does anyone have any experience or know where to check?
Heat and AC are both off and I can smell it. Mostly in front of driver and passenger side.
Old Nov 26, 2021 | 10:42 PM
StevesGS's Avatar
StevesGS
Check and make sure sunroof is sealing properly, sometimes the water can leak in through there and run all the way down to the carpet making it hard to detect a leak
Old Nov 26, 2021 | 11:18 PM
irobot2090's Avatar
irobot2090
Yeah, already check the sunroof interior and didn't see or feel any water there.
Old Nov 27, 2021 | 01:04 AM
veeinc's Avatar
veeinc
Have you tried changing your in-cabin filter to one with charcoal? There are several available on sites like Amazon.
For good measure, you can also spray the vents with Lysol or Ozium with the air running.
Here is a thread that discusses some options https://www.clublexus.com/forums/ls-...ner-smell.html
Old Nov 27, 2021 | 05:44 AM
bc6152's Avatar
bc6152
Check the trunk and remove the spare to see if any water intrusion...
Old Nov 27, 2021 | 01:46 PM
irobot2090's Avatar
irobot2090
will try that. Thanks
Old Nov 27, 2021 | 01:47 PM
irobot2090's Avatar
irobot2090
yeah, already checked and no water. Thanks
Old Nov 27, 2021 | 01:48 PM
irobot2090's Avatar
irobot2090
Does anyone know where’s the drainage hole? Need to check to see if it clogged.
Old Nov 28, 2021 | 02:30 PM
mikemu30's Avatar
mikemu30
If your sunroof drains were clogged, you'd likely have water inside. They drain down the A pillar I believe.
bacosta007
Jun 25, 2019 05:34 PM
mrvic
Aug 25, 2018 09:05 PM
jakenbake
Jan 12, 2015 12:02 PM
94Blexus
Jun 27, 2013 08:50 PM
bcorey
May 28, 2013 09:17 PM
